It is currently Thu May 23, 2024 12:30 am
 Post subject: SPEC clutch broken
PostPosted: Tue Feb 12, 2008 11:09 pm
Voted off the island
Hey
I picked up a stage 3 for a fwd talon 91 last year. I drove car for about 1200km in city along with drag runs and dyno pulls. After having a problem with tranny I went a head and see why clutch was not working. After having car on host to do a timing bely just along with upgrades I went ahead to have my tranny built. After pulling out the tranny this is what I found of left of my spec clutch (PICS)
PostPosted: Thu Feb 14, 2008 9:51 pm
thats absolutely awful, I wouldnt run anything other than a ACT
PostPosted: Thu Feb 14, 2008 11:06 pm
That sucks man. I also have a spec clutch in the colt, I did have the springs in the disk come out and do some damage:
Image Image
After I shipped it back to them for them to decide if it was covered by warranty they called back and left a voice mail, it was not covered. A few days later when I got back to town, I returned the call, argued on the phone for a few minutes then told them I wanted it shipped back to me (in Canada). I said I would take the springs out and weld the center pieces together, since I do still own a clutch. The next day I received another call, they admitted there was a fault in the design, the metal was too soft and too thin. I got a new clutch on warranty.
That clutch never made a dyno pull, no runs at the drag strip. There was about 6 tanks of fuel burnt with that clutch. The replacement is much better, no problems yet with it. After this experience I dont think I would get a spec again, we are not the only ones with problems with spec.
Good luck.
PostPosted: Sat Feb 16, 2008 1:25 pm
i had a stage 3 spec, that had issues from day one. it would slip on anythingmore then 1/2 pedal, and this was n/a!
i had to have it removed, sent back to sec, so they could make sure it wasnt install error. they admitted fault, and sent me a replacement. and once again, right off the bat, problems. car was not even drivable... i couldnt believe this shit!
after that, i gave up on spec all together. ive ran act's, clutchmasters, centerforce, tons of clutch's, AND NEVER ONCE A FAILURE! ive never even killed a stock OEM clutch on a car. yet two of these piece of shit SPECS couldnt even handle being babied through a break in period.
i bought a southbend DXD afterwords, and the clutch is still in the car after 6 years, and havent had one problem at all.
YOU COULDNT PAY ME TO INSTALL A SPEC IN ONE OF MY OWN CAR'S!
PostPosted: Sat Feb 16, 2008 1:35 pm
My friend has gone through two Spec's before he switched. This was in a lightly modified Nissan NX2000. About 350whp. And it was one of their "stage three" clutches. Pure junk. I would also not run anything except ACT. Or if I had the money, Tilton, or Ogura.
89' Mitsubishi Mirage Turbo.
PostPosted: Sat Feb 16, 2008 9:53 pm
Holy Fn defect :o
If I had a dollar for every V8 beaten by a colt I would be a millionaire. But I would still be driving my colt.
PostPosted: Fri Mar 14, 2008 11:14 am
Well Im sure they knew if you put that back in there that it could be very dangerous. That peice could become a projectile and potentially kill someone.
PostPosted: Fri Mar 14, 2008 11:23 am
Yeah, I wasn't about to put it back in the car. I just wanted it to hang on the wall of broken parts. I seen a what happens when a flywheel blows up on a dsm below 2000 rpm, pieces hit the hood and firewall. I couldn't imagine that happening over 6000 rpm.
- Works in da bush
PostPosted: Fri Apr 04, 2008 11:14 pm
Before i had my colt i had and Infinti G20 DET swapped, i had a spec clutch it the car and destroyed it! Same deal with the disk, the springs broke out and messed everything up....crap if you ask me.
89 Colt GT, 4G63T, 60-1 @ 30 psi, NX wet 75 shot...
97 Jeep Wrangler
PostPosted: Sun Aug 03, 2008 10:07 pm
Digital Baby Troll
I had a SPEC clutch on my SHO, it was in for about a month and after 500 miles the pressure plate snapped just like yours. I tried to get them to replace it under warranty but I had to send the busted one in first, which meant I needed a new clutch first. Long story short I got screwed out of the warranty and haven't supported SPEC since.
89 Mirage Turbo-Money pit
99 Jeep Cherokee-1/4 Epic
01 Cobra-Too Thirsty
72 Dodge-Pedo'van
PostPosted: Sun Aug 03, 2008 10:16 pm
sweet i guess i'll be installing a spec this weekend... haha
PostPosted: Wed Aug 06, 2008 3:19 am
Owner/Admin
not enough boost on that clutch ouch!!!!!!! :x
PostPosted: Wed Aug 06, 2008 3:27 am
Owner/Admin
i can say that clutch power makes good clutches i got one in my car, ACT is a good clutch also :D
