It is currently Sun Oct 26, 2025 7:35 pm
Post new topic  Reply to topic  [ 33 posts ]  Go to page 1 2 3 Next
PostPosted: Sat Jun 21, 2008 11:09 am
Its for the left side (driver side), I have the AWD half shaft, but for the outer half I tried putting in a 1g AWD axle and its too long. Do I need to get the 1.6 turbo mirage axle? I called discount, pep boys, and carquest and they dont carry them! Thanks!
PostPosted: Sat Jun 21, 2008 11:38 am
Would this one work? It says driver side...
http://cgi.ebay.com/ebaymotors/CV-AXLE- ... .m20.l1116
91 Galant VR4
PostPosted: Sat Jun 21, 2008 11:48 am
Alot of places have them listed under "89 Mirage Turbo Axle" but the only place i'd trust is Napa or Carquest.
In case you can't find it let me know.
A buddy of mine has a used one from his set.
PostPosted: Sat Jun 21, 2008 11:51 am
i called napa and they "say" they have it, but id have to go check, carquest by me says they dont have it :(
91 Galant VR4
PostPosted: Sat Jun 21, 2008 12:02 pm
What happened to the one that was in it? It was a reman from Carquest.
PostPosted: Sat Jun 21, 2008 12:04 pm
It went SNAP! Should have slipped the clutch more, too much dumping. And now carquest is telling me they dont have one :(
91 Galant VR4
PostPosted: Sat Jun 21, 2008 12:05 pm
Like i said if you need it let me know.
I'll just give my friend a call and see if he'll sell it and for how much.
PostPosted: Sat Jun 21, 2008 12:07 pm
now napa is telling me they dont have it, if you could contact your friend that would be great!
91 Galant VR4
PostPosted: Sat Jun 21, 2008 12:14 pm
I've often wondered if converting to 1G DSM front spindles would cure the axle problems and let you use AWD DSM axles? I wonder if the DSM spindles are spaced out a little more? I remember reading that Mr. HYDE successfully used a 1g AWD DSM axle in his Colt but I am almost positive that he had DSM/GVR4 spindles.
Mark, if you compare the Colt axle to the dsm axle how much of a difference is there length wise?
PostPosted: Sat Jun 21, 2008 12:42 pm
Well I dont have the colt axle since i cant find it anywhere, and now the awd axle is being a real pain the ass trying to get out. When i get the colt axle and get the awd axle out i will compare and take pics!
91 Galant VR4
PostPosted: Sat Jun 21, 2008 1:33 pm
I would certainly suggest doing that. I cant remember if I used the entire drivers side axle assembly in my old Turbo CSM or if I used JUST the half shaft.
I remember posting a comment a while back on the same issue and lilevo was kind enough to post that JUST the iner axle was the same length, not the outer axle.
Sorry I cant be of more help
Geoff
2013 Genesis 5.0 RSPEC
88 Mazda Turbo II- LSX7
89 2.0 Turbo Colt
13 Ducati 1199 Panigale
PostPosted: Sat Jun 21, 2008 3:02 pm
You need to use a Turbo Mirage axle. DSM axles will not work. I sell the axle you need at my work, it's ~$90 shipped brand new without a core charge.
PostPosted: Sat Jun 21, 2008 5:42 pm
Carquest does have them, they have to be ordered though. Don't ask them to look them up. Get the part numbers here and have them the one you need.
PostPosted: Sat Jun 21, 2008 9:46 pm
I wonder if swapping over to dsm spindles would widen things up a bit more in order to use the slightly longer dsm axle? There must be an explanation of why Mr. Hyde was able to make a dsm axle fit in his car.
PostPosted: Sun Jun 22, 2008 12:13 am
you can put dsm control arms on and widen the front track, or use the dsm one piece axle with stockish ride height and not have a problem
