CaptainT,
Can you just get oversize 2G pistons (.040 over?) and drop them in the block? That would be sweet
I know it would require at a minimum a hone, but this could be a cheap route to turbo town
The SOHC head would yield insanely high compression if you just dropped in the pistons.
Thinking about this some more, 4G63T pistons won't work, how would you make up for the extra 6mm deck height? Oh well I guess I'll just drop in a 6bolt.
Good point. You would need custom stroker pistons. The same rule applies for the compression ratio, you need a DOHC head.
