It is currently Sat Nov 01, 2025 5:12 am
Post new topic  Reply to topic  [ 160 posts ]  Go to page Previous 1 2 3 4 511 Next
PostPosted: Mon Mar 31, 2008 12:10 am
You dont need a 4g63, the 4g61 is a awesome motor! It will rev higher then a 4g63, and also it will hold together better then a 4g63 cuz of the shorter stroke.
modify the 4g61 till it blows, then MAYBE put in a 63.
They rev just as high as a 4g63. Yeah, the 61t has a short stroke, but the crappy stock valvetrain will give out long before anything else, that and the lack of a decent drivetrain.
PostPosted: Wed Sep 10, 2008 7:47 am
Hello I m back !
With a small update from France ...
Since 4 month i worked hard on my colt and this is m y futur setup .
Suspension Kyb gr2 front and rear with new Kyb bump and upper mount from shockwarehouse.com .
Short springs from H&R ref 29710
Outer track rod end from Camskill.uk
Brakes
front: drilled from Camskill.uk with pro act 328 pad from Rockauto
rear: stock but news ...
G stop goodridge 8 lines ref 26043 in command from Performancepeddler.com ...Thanks coltmax 8)
Odyssey batterie pc680 from motobatteries.com
Water air IC from lindseyracing.com with flojet pump 3.2gl/m and clim evaporator and fan in stock place.
MBC hallman evolution RX in cabin with 12 psi of boost i think !
Bcs and canister removed .
New fuel filter and fuel pump rewired .
Cath oil tank home made with a clim botlle
Air filter putting in the fender with custom piping for more clearance .
Custom outer pipe for the 11B
OBX water coolant tank from Ebay
AEM digital voltmeter and stainless Steel clutch line from racetechperformance.com
Electric windows conversion
After a paint job in original color code R52 this winter .
Any question or help are accepted ...
Many thanks for your help in this forum
PostPosted: Wed Sep 10, 2008 8:32 am
Pictures of all of this sweet kit installed please, et S'il vous plait? :lol:
PostPosted: Wed Sep 10, 2008 11:03 am
In progress ....
Please wait !
Maybe tonight on my signature or WWW
With 2 or 3 questions in newbie tech forum for you !
Thanks for your time
PostPosted: Thu Sep 11, 2008 2:43 am
Hello
Update on my signature below .
Any suggestion are accepted thanks .
Misubishi colt 1400glx 80 VS Dodge colt gt turbo 89 French language sorry
PostPosted: Thu Sep 11, 2008 9:26 am
I would like to say that your car never ceases to amaze me! Keep up the hard/good work, it will give you a smile ear to ear when you get to driver this car in fully modified trim. 8)
Are your headlamps the standard ones from the US the car was imported with?
PostPosted: Fri Sep 12, 2008 7:12 pm
Yes but i have much time for modified this colt , i hope drive this winter after paint job ...
For your information , after importation many glasses are changed because in europe different standard is requested .
Only safety glasses and electrical connection securised ...Headlamps front and rear, blinks, bulbs and sockets etc ...
PostPosted: Sun Sep 14, 2008 5:23 pm
I think he is using bablefish to translate
PostPosted: Wed Sep 17, 2008 3:07 pm
Hello
For TrevTec, YES i use bablefish sometimes for translate !
Because my english language is very poor after 15 years ...
I have a bad news for Goodridge G-stop 26043 ! This part has been discontinued from the manufacturer ...
I hope obtains a Techna brake lines from www.horsepowerfreaks.com !
Any suggestion are accepted thanks !
PostPosted: Wed Sep 17, 2008 4:57 pm
4g61t Delinquent
wow looking at the pictures and by researching H&R's german page, they still make springs for our car.
PN - 29710-1
I own a CSM.
 Post subject: Re: Dodge colt gt 89
PostPosted: Fri Jan 02, 2009 6:58 am
H&R 29710 global view
Front left view with Techna brake lines Mit 810 fit perfectly !
Happy new year ...
 Post subject: Re:
PostPosted: Fri Jan 02, 2009 8:28 am
Hello
I think your web page is down :(
PostPosted: Sat Jan 03, 2009 9:22 am
yes I know! I work for the best link maybe a myspace ...
PostPosted: Wed Jan 14, 2009 5:22 pm
Update for custom exhaust
3 P megan downpipe and 2.5 P final, resonator and muffler :)
PostPosted: Wed Jan 14, 2009 6:37 pm
^ That looks REALLY good! Where did you get that exhaust at? I think we'd all like to know.
