It is currently Sat Nov 01, 2025 6:05 am
 Post subject: Header for the 61t
PostPosted: Sun Mar 23, 2008 1:45 pm
Yesterday on my way home from work I developed an exhaust leak. I was hoping to find a missing bolt or something of that nature. No such luck...here is what I found:
So yeah...broke right off the flange. Great stuff I tell you!
Take a guess what brand it is...not that it will be hard to figure it out lol.
So anyways..Obviously I need a new one. I need to go the cheapest way I can, but I don't wanna be doing this again in 6 months. So whats a good brand that is decently priced with decent quality? Maybe I should just get a cast manifold instead?
PostPosted: Sun Mar 23, 2008 1:58 pm
If you want something durable, but don't want to shell out lots of money, then cast is your only option.
PostPosted: Sun Mar 23, 2008 2:01 pm
Check out the Forced Performance cast race manifold. I'm sure you couldn't go wrong with that. It's sick! :twisted:
PostPosted: Mon Mar 24, 2008 2:39 pm
Yeah the fp cast mani is nice. Not affordable at the moment lol. What would be the best cast manifold for me to get as far as a factory one? 2g eclipse?
PostPosted: Mon Mar 24, 2008 2:47 pm
Evo 3 is the best, but 1/2G models all bolt right up to the 4g61T with no issues. I'm not sure if the collector point is raised or lowered, as I had trouble using my 2.5" exhaust made for the 4g61t deck heigh, when I installed my 4g63t, but I stayed with the 1G Manifold through the whole process. Generally I think the cast pieces from Mitsu keep the turbo located in the same place because the lines for oil and water have to stay similarily spaced IIRC.
PostPosted: Mon Mar 24, 2008 3:58 pm
Not sure if it's still going, but 3 weeks ago I got an EVO 3 manifold from RRE. It was a VERY competitive price. I'd give them a call. The reason OEM's use cast iron for manifolds IS cost and durability... I suggest you do the same.
Ryan
PostPosted: Mon Mar 24, 2008 4:21 pm
Yeah, I had a 2G exhaust manifold on my Turbo Mirage for over a year, and it held up perfectly. No cracks, and I was boosting 18psi regularly. However, the Evo 3 manifold is more durable and has slightly bigger runners than the 2G exhaust manifold.
PostPosted: Mon Mar 24, 2008 4:53 pm
Who told you the EVO III manifold was more durable? They're the same thing. The EVO III just has a slightly larger collector, perhaps the center divider is a tad more beefy.
PostPosted: Mon Mar 24, 2008 5:05 pm
perhaps the center divider is a tad more beefy.[/quote]
Right on. :)
