It is currently Mon Oct 20, 2025 9:38 pm
PostPosted: Thu Jan 24, 2008 11:25 am
Its really not as laggy as I thought it was gonna be, we have 32 psi by 6000 RPMs. I know people with 37Rs that spool slower.
PostPosted: Sun Jan 27, 2008 4:39 pm
http://youtube.com/watch?v=_IKk3lHbBXw
Heres a Vid of our 1st run. We got 3 total but this was the best ET. He only shifted at 8000RPMs on this run and it just bogged a little between shifts. Second run he dumped the clutch too fast and fell on its face, ran it up to 9000 that time and it went 10.5@142. 3Rd run was a sick launch and real hard into second and it just spun the tires all the way to redline and he shifted to 3rd without enough speed and ended up at 4000 RPMs...ran like 11.3@133. This was at 37 psi of boost with some timing removed, so around 650hp or so.
PostPosted: Sun Jan 27, 2008 4:50 pm
Nice! That thing sounds bitchin'
PostPosted: Sun Jan 27, 2008 6:14 pm
Good stuff. Looking foward to some runs once you guys get it dialed in :twisted:
PostPosted: Mon Mar 10, 2008 1:37 pm
http://www.youtube.com/watch?v=rMiZ7Y_tcJM
Just got back from CMI in Sacremento California, got #1 qualifier in the quick 8 with this pass. Had some minor clutch issues and ended up loosing in the semis, ring gear fell off the flywheel. Its going 120 in the 8th now. Needs to shift a little higher RPM in 3rd and 4th shift to keep it in boost I think.
PostPosted: Mon Mar 10, 2008 1:43 pm
Damn, son. 120mph in the 1/8th is no joke. :salute:
PostPosted: Mon Mar 10, 2008 1:53 pm
Damn that is super impressive for so little time running. Are you aiming to catch Jake M.? Also are you spraying the car?
PostPosted: Mon Mar 10, 2008 6:37 pm
Nice times 8)
PostPosted: Mon Mar 10, 2008 7:14 pm
Sick times 120 in the 1/8 god damn..
Str8fuct......
PostPosted: Tue Mar 11, 2008 10:20 am
Theres no nitrous on the car either which is the most impressive part. Its really bogging into 3rd and 4th but I think some 10K RPM shifts will cure that. I think another 7-8 psi of boost and higher shift points and this could be an 8 second car.
PostPosted: Tue Mar 11, 2008 10:50 am
You could use NLTS and antilag between shifts. That will cure the bogging down. I would rather shift my car at 8500-9500 than 10000 any day.
Steven
1985 Mitsubishi Cordia
Build in progress
PostPosted: Tue Mar 11, 2008 11:01 am
Steven
Yeah, anti-lag and a close-ratio gearbox is your friend. My buddy's 42R-powered 2g didn't fall out its powerband in-between shifts, and that was like 40psi on a low-compression 2.0 liter.
PostPosted: Fri Mar 14, 2008 12:07 am
Were using the antilag off the line but Im not sure if the clutch switch was enabled on that run. For only being the 4th pass in the car it runs pretty fast. I guess were the fastest 5 speed car on DSM Link now and also the highest HP car on DSM link and we havent even been on a dynojet yet since all we have in town is an AWD Mustang.
PostPosted: Fri Mar 14, 2008 8:14 am
The DNP seems to be holding up well. Have you had any problems with it?
Now you just need to catch that 8 second mirage for the quickest car on the link boards :)
PostPosted: Fri Mar 14, 2008 11:09 am
Were working on it :lol:
There are two brackets that are welded from the T4 flange to the Head flange to help support weight and they have broken off at the head flange. The manifold needs to come off to weld it back on. Besides that it seems ok. The material for the wastegate crossover is alot thinner and the only reason I know is because its the only part to turn red at WOT on the dyno.
