It is currently Mon Oct 20, 2025 4:57 am
 Post subject: new member from mpf
PostPosted: Sat Dec 01, 2007 9:42 pm
hello, my name is Andie. i've been a member on mpf for almost 7 years and have always lurked around on here so i figured i should introduce myself. my 5g is almost finished, and i'm looking for either a 3g hatch or a 4g mirage sedan for my next project car/4g63t swap.
my current car:
2000 mirage ls coupe with a built sohc 1.8l turbo.
its made well over 400whp on the dyno, but hasn't yet been back in its current state of tune with the new turbo. i'm figuring it'll be somewhere around 450-475whp@30psi. has been 12.1@119mph with 22psi in the 1/4.
should go 11s in the spring, axels allowing, since it is now tuned for 30psi.
mods list:
microtech ltx8s ecu
4 x external msd blaster coils
.020 over ross pistons with oversize chrome moly 21mm wrist pins
pauter rods
clevite 77 race bearings
micro polished crank
port&polished head with 3 angle valve job
rpw stage 2 turbo cam
rpw valve springs
97 adj. lifters
stock headgasket
arp headstuds
port matched 4g92 mivec intake manifold
60mm mivec t/b
aerospeed adj. cam gear
precision turbo 780cc injectors
s/s log style manifold
garrett t3/60-1 turbo
precision turbo 31.50"x8"x3.50" fmic
2.5" and 2.75" aluminum i/c piping
50mm tial bov
38mm tial wastegate
3" s/s down pipe
3" exaust with black apexi n1
act extreme pressure plate
act 4 puck race disk
fidanza aluminum flywheel
genuine mitsu mivec helical lsd
walbro 255lph in tank fuel pump
bosch inline fuel pump
greddy profec b spec 2 boost control
greddy peak and hold egt
apexi turbo timer
zeitronix wideband afr with lcd display
autometer boost and oil pressure gages
autometer pro shift lite
corbeau forza seats
moroso sealed and vented battery box
moroso battery master cut-off switch
spal 10" fan
flex-a-lite 12" fan
allstar performance oil catch can
jazz radiator overflow
kyb gr2 struts
ground control coilovers
whiteline 3 way adjustable rear sway bar
tein front pillow ball mounts
15"x6.5" rota slipstreams
lenso vpd drag wheels 13"x7.5" with m/t 24.5"x8" et drag slicks
custom front and rear upper stb's
custom rear lower tie bar
vis evo c/f hood
sparco hood pins
evo 5 tails
evo side markers
civic front lip
ls side skirts
oem rear pods
pics:
it has been breaking drivers side axels at the track launching with the 2step, so it will be getting some driveshaftshop axels and an evo5 koyo aluminum radiator over its winter hibernation.
now i just need to find a 3g hatch or a 4g mirage sedan for a daily driver.
i have been using my ae86 but thats getting a new gze turbo motor over the winter so it needs to come off the road soon.
i look forward to contributing to the 4g61t.org community
:stickman:
PostPosted: Sat Dec 01, 2007 9:56 pm
Hey welcome man! This is Chris Mitsuman from MPF!
I think you'll really like it here!
PostPosted: Sat Dec 01, 2007 9:58 pm
hey chris, thanks.
PostPosted: Sat Dec 01, 2007 10:22 pm
Very nice ride man, your attention to detail is second to none.
PostPosted: Sun Dec 02, 2007 1:03 am
Clean car(s). That's very impressive power for a SOHC 4G93. Please put a location in your profile. :wink:
PostPosted: Sun Dec 02, 2007 1:11 am
Hey Boss :)
PostPosted: Sun Dec 02, 2007 7:10 pm
I'm still trying to really dig the newer coupe styling but that aside, this picture says it all: Attention to detail as 89Mirageman stated, almost doesn't cover it!
PostPosted: Sun Dec 02, 2007 7:18 pm
Very very nice man.
- Works in da bush
PostPosted: Sun Dec 02, 2007 7:34 pm
thanks alot guys!
PostPosted: Sun Dec 02, 2007 8:19 pm
Great job with the sohc 1.8. The car looks great!
PostPosted: Sun Dec 02, 2007 9:48 pm
+1 :D
Geoff
2013 Genesis 5.0 RSPEC
88 Mazda Turbo II- LSX7
89 2.0 Turbo Colt
13 Ducati 1199 Panigale
PostPosted: Mon Dec 03, 2007 8:04 am
Excellent work! As the others stated, God is in details!
PostPosted: Tue Dec 18, 2007 10:05 pm
That's insane how you got the a built 4g93 to your favor and the engine bay looks great. Also the exterior looks outstanding, simple and clean. Great work man.
92 Eagle Talon FWD Auto (Drag Car)
