It is currently Tue Oct 21, 2025 3:51 pm
Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 178 posts ]  Go to page Previous 13 4 5 6 712 Next
PostPosted: Mon May 21, 2007 5:34 pm
Well the car gets started for shure this week and it should be the nicest swap around when finished. :ANAL:
Adam
93'FD Touring non-seq
05'WRX
PostPosted: Mon May 21, 2007 6:06 pm
You certainly cleaned everything real well. :lol:
PostPosted: Thu Jun 14, 2007 6:33 pm
yeah, no problem, that is what i plan on doing, it just seems a lot more simple then changing the arms on the tranny. Im pretty sure the dsm shifter assembly will even bolt in but im gonna weld mine in with 2-3" spacers under it to raise the shifter up closer to the steering wheel.
:evil: Well, I just set the dsm shifter in place to see, and they are not a straight "bolt-in". I have a dsm that has been "modified". You have to set up a couple of adjusting bolts, fore and aft, with lock stops to keep the shifter from throwing too long. The base is too short, but it seems reasonable that the two plates can be cut and front ends rewelded to achieve a bolt-in. I have the shifter raised on a couple of steel U-bars to lift about 4". I am not going to modify the plate until the rest is done (like Sept.). Oh, the dsm cables are longer.
PostPosted: Mon Jul 02, 2007 8:34 am
Well the car has been sitting at the shop for over three months now and I'm told it will be started on July 5th when they get back from vacation. I hope so cause I want my car...
Hey atleast I'm getting free storage.
Adam
05'WRX
PostPosted: Wed Aug 08, 2007 8:29 pm
Cars looking good, just letting you guys know I'm still alive.
PostPosted: Wed Aug 08, 2007 10:44 pm
Get it DONE ALREADY!!! :finga:
Nice to see you're still around fella!!
Geoff
2013 Genesis 5.0 RSPEC
88 Mazda Turbo II- LSX7
89 2.0 Turbo Colt
13 Ducati 1199 Panigale
PostPosted: Wed Aug 08, 2007 11:35 pm
Thanks for resurrecting this thread. Simply the nicest swap I've seen. good job!
PostPosted: Wed Aug 08, 2007 11:43 pm
Thanks, I put the job in the hands of one of the only people in STL I would trust to do a great job. Might take soem time but I'm hoping by spring to have a very nice car eating up the copmatition at the track and street.
PostPosted: Thu Aug 09, 2007 2:56 pm
Pics would be nice. From the sound of it, you got the engine dropped in and everything. I really can't wait to see how it turns out.
-Seth
PostPosted: Fri Aug 10, 2007 9:19 am
half completed front sway bar bushings
Back in one of the early posts and pics, you noted a creation of bushings for the front antisway bar. Could you give some info. on what you did? What material did you use? Source? Did you shape it or just leave it circular on the outside and tighten it in the oblong bracket? Also those hubs look GREAT. I assume you used a "clear" on them. I painted mine black, but they don't look nearly as good. (envious) Thanks for help, Bill
PostPosted: Fri Aug 10, 2007 6:54 pm
quote]
I thought I sent you a relpy but when i looked in my sent box I didnt see one, weird. That project was abandoned dues to lazyness and having two perfectly new oem bushing laying around. They didnt make it much further then the pic. I did talk to Matt the guy doing my swap today he sd things should start moving again by wendsay.
PostPosted: Sat Oct 27, 2007 10:52 am
UPDATE
Cars is on one of the lifts at the shop so where getting closer. We decided to go with a chrome moly cage,to save weight. Hope to see progress this week..
Adam
05'WRX
PostPosted: Sat Oct 27, 2007 11:26 am
<----- Hope to see pictures this week!
PostPosted: Fri Nov 23, 2007 2:19 am
Any updates?
PostPosted: Fri Nov 23, 2007 10:25 am
What are you using to blast these parts? Media blaster... sandblaster?
