Most will say it's a a bad idea without really saying why. Here's why: The cooling capability of the 4G15 is marginal. It's enough for a stock and slightly modified engine, but once you turbocharge it, the head/block cant stay cool enough.
Here's how to go the turbo 4g6x route cheap:
Find yourself a 4g63 SOHC engine. Plenty of them out there and very cheap. It's the same block as the 4G63 DOHC and it's the same as the turbo DOHC engines minus the oil squirters. If you go with the SOHC engine, you'll have to find a DOHC head. the DOHC is the same as the turbo version. I believe the crank and rods are the same as the turbo. You'll need turbo pistons. Order them off ebay or goto your 'discount auto parts' store and get some badger pistons or whatever cheapies they have there.
Use a hyundai KM210, equivalent to a F5M31. Proper turbo tranny would be a f5m33. it just wont be able to take as much torque but will be fine for stock and mildly modified turbo engines (not CRAZY modified).
ecu & harness can be found on ebay. People here sell them cheap too. There's also a writeup somewhere that tells you how to mod a NA harness for turbo use. You still need the turbo ECU though. You could always megasquirt and not worry about that.
proper injectors. 390cc for automatic ecu, 450cc for manual ecu. if you megasquirt, you can use whatever you want.
turbocharger/manifold... ebay or here.
BOV, MAF, IC... BOV is generic. get one off ebay. one of the cheap chinese ones for now. MAF... I dunno if you can use a NA and modify or not. search on that one. IC... ebay or here. Plenty of people selling the stock SMIC for cheap.
mounts... all of them are the same except the tranny and rear mount I believe. Someone here is starting to make duplicates, but also some people sell pulls from the junkyard. check the FS section.
fue pump... stock will do for stock. once you start modifying, get a 255lph pump from ebay.
a lot of this will carry over to a 4g15 turbo job, but the 4g6x block is so much better for turbo use.
most of what he said was correct...........most
1. you need mounts from an elentra or sonota.........just get all of them its easier
2. modding the n/a wiring harness is a slut
3. Oil sqirter or not your still missing an oil pan, oil lines and alot of other miscellaneous shit, like knock sensor ect.........
4. you can EASILY find a beat to hell fwd turbo and be done with it
5. a stock pump is garbage with a turbo motor.
NOW if you still want to turbo that hunk of crap here is the way to do it
1. the stock mani would make an excellent candidate for a turbo mani, go honda style and weld on an adapter plate
2. smic, bov all that shit........go crazy spend 40$ and go nuts
3. get a 4g37 ecu and an safc, the 4g37 ecu will allow you to tune for injectors 390's is what i would recomend, 450's are pushing the limits of the safc
4.
IMPORTANT ...... get a dsm radiator this is a must like skrenos said the cooling is for shit on the 4g15, i mean have you EVER seen the size of you radiator?
5. Coolant lines --rerout them from tb
6. almost forgot........FUEL PUMP a dsm one will work wonders
sure i'm prolly missing some stuff, but in all reality and being honest you prolly won't attempt this, or try and get bored and give up, those are strong probabilities
but whatever you do good luck
