It is currently Sat Oct 25, 2025 4:48 am
 Post subject: cracked exhaust manifold
PostPosted: Mon Jul 23, 2007 3:16 pm
I pulkled the heat shield off as I am preparing for replacing the head gasket..well right in the middle the manny has a 4" crack running down it.... if there a place I can get a new one..or a header?..thanks much..
Steve < now has a 89 and 90 colt
PostPosted: Mon Jul 23, 2007 3:24 pm
Junkyards are your friend. :wink:
PostPosted: Mon Jul 23, 2007 4:38 pm
Junkyards full of Scoupe that have tubular manifolds, or any CSM left without a crack in the manifold. Ebay will almost guaranteed have a manifold, brand new for the $80 US range, plus shipping.
Edit: searched and found this, not even worth putting on an old part for the price. http://cgi.ebay.com/ebaymotors/EXHAUST- ... dZViewItem :o 8)
PostPosted: Tue Jul 24, 2007 1:11 pm
I heard on another forum that the header that Pacesetter makes for the 84-87 CRX Si 1.6 will fit our motors are are FAIRLY priced. You might want to check that out unless you're looking for a factory piece, then you might want to try EBay.
PostPosted: Tue Jul 24, 2007 6:46 pm
so we called pacesetters today from the shop I work at.. the guy actually said he used the gasket to see if it matched up and it does not...so im not sure if that guy modified the honda 1 to make it work... anyways..
what years scoup can I use? same as the csm? 88-90?...
all the ones I see on e-bay (quick search and fast looks).. showed a 87-89...then 91/92... no 90s? not sure why theres no listings for a 90?..
PostPosted: Fri Jul 27, 2007 11:20 am
hey guys, what other manifold can fit the colt HB 92 w/auto transmission ? I have the same cracked manifold, I call carparts on e-bay but they do not ship to canada ! bump !
Thanks for the info.
PostPosted: Fri Jul 27, 2007 11:22 am
Hey flying eagle you said you have one manifold sitting in your garage, do u still have it ? I am going to montreal the longweekend maybe I can see if I go to Ottawa to pick it up, please let me know.
