It is currently Mon Nov 03, 2025 12:52 pm
Post new topic  Reply to topic  [ 76 posts ]  Go to page Previous 1 2 3 4 5 6 Next
PostPosted: Fri Apr 27, 2007 1:12 am
i like that idea with the exhaust.
Clay M.
1989 4G63T Colt GT AWD - 10.2@146
PostPosted: Fri Apr 27, 2007 1:34 am
Thanks, we'll see how it works out.
http://home.tiora.net/davidc/Racing/Bar ... davesz.jpg
PostPosted: Sat Apr 28, 2007 12:15 am
WHOOOT!! I got my driveshaft back from the driveline shop today. VERY nice job I must say.
The Middle piece is the front section of a stock DSM driveshaft with the U-joint removed. The bottom piece is the rear carrier bearing removed from the two rear sections of the driveshaft. The Top piece is the modified rear piece.
And now when I combine the new piece with the original front section, I get this!
All I need to do now is fab up a mount for that carrier bearing, finish the ehxaust, and fill it up with fluids!
PostPosted: Sat Apr 28, 2007 11:20 pm
Exhaust done! Tomorrow I might drive my car in AWD mode :-)
PostPosted: Sun Apr 29, 2007 3:14 am
dont forget the video camera... :D
PostPosted: Sun Apr 29, 2007 12:16 pm
Video camera will be there, no problem. Getting the video onto the computer, now thats a problem!
PostPosted: Sun Apr 29, 2007 6:44 pm
So I woke up early to get a start on the car, I had to fabricate the mount for the carrier bearing in here:
I started by making brackets like these with holes for the studs.
Tacked them up into place
WHOOT!!!
PostPosted: Sun Apr 29, 2007 6:51 pm
http://home.tiora.net/davidc/Colt/AWD%2 ... CF0077.AVI
PostPosted: Mon Apr 30, 2007 10:13 pm
tight fit w/ the axle & the exhaust. i like. drove it yet???
PostPosted: Mon Apr 30, 2007 10:43 pm
Thanks! yeah its close, but they aren't touching, nor will they. I did drive it around the block today. Come to find out the trans I got for it is VERY bad. :-( such a bummer. I'll get a replacement transmission before the week and give it another shot.
PostPosted: Tue May 01, 2007 9:56 am
HAHAH. dumbest vid EVER!
glad you finished it. and glad i could help out a bit
PostPosted: Tue May 01, 2007 10:21 am
Thats the cleanest driveshaft yeat for this conversion
PostPosted: Tue May 01, 2007 5:27 pm
Mine was VERY nice, till i got it :axe: Open DP makes everything nasty
PostPosted: Tue May 01, 2007 6:11 pm
Quit trying to steal all the glory, you jackass!
:P
PostPosted: Tue May 01, 2007 11:24 pm
Thanks for the compliments guys! John, you are going to hell. j/k! Your help certainly was very usefull and I dont think I could have gone through this swap as smoothly as I did without it. But in my defence, I bet you i'll go faster then 98 mph in the 1/4! :lol:
