It is currently Tue Oct 21, 2025 6:37 pm
PostPosted: Sun Apr 22, 2007 8:19 pm
ok i am new to this...here is the situation...i have a 2g 95 awd tsi...i want to swap everything over to a colt...
will my 2g trans work...if so what motor/trans mounts will i be using...
also will my 2g rear end work...and if so what axles and hub should i use...how about the subframe...thanks alot...
PostPosted: Sun Apr 22, 2007 9:23 pm
Sure. it'll all work. :drinkers:
PostPosted: Sun Apr 22, 2007 9:36 pm
are you sure...what rear hubs do i use...
PostPosted: Sun Apr 22, 2007 10:06 pm
well 2gs are much wider than 1gs so you might have a issue with the awd sticky out. also why would you wanna part out a 2g awd i say sell it and get awd parts from a 1g. 2g dsms are too nice to part out :wink:
also forgot to mention that 2g awd suspension is soo different than that 1gs and you may have alot of problems too the swap to a colt. so my opinion is that so 1g stuff trust save you alot of headaches.
PostPosted: Sun Apr 22, 2007 10:56 pm
well i was thinking about throwing a stock 6 bolt in the 2g dsm...and make it fwd...
taking the awd stuff and built motor stuff out of the 2g and putting it the a colt...
PostPosted: Sun Apr 22, 2007 11:08 pm
2g stuff wont work. Trans yes, Rear no.
PostPosted: Mon Apr 23, 2007 6:53 am
heres the 2g rear...
http://www.dsmtuners.com/forums/attachm ... 1131522506
and here is the 1g rear....
im sure its not impossible but you would be the first... just keep that in mind and remember there are lots of pics and documentation of the 1g rear swap into a CSM around here.
PostPosted: Mon Apr 23, 2007 9:56 am
so everyting pictured in that 1g rear picture gets used correct...
only thing that needs to be fabricated is the mounting points correct...thanks...
PostPosted: Mon Apr 23, 2007 1:05 pm
:evil: Damn! I hate to have to show how unknowledgeable I am. I am still gathering parts while trying to get my car together. I have a 1gDSM with a 3bolt. I have an awd tranny and new flywheel. I also have the 4bolt cups and axles. I had planned to use vr4 hubs, but ran into confusion. I did find a 2g Talon being parted, so I bought EVERYTHING=rear end, hubs, knuckles, brakes (including the booster and master), front and rear axles, and transfer case. I have vr4 front hubs now. I got the idea of putting in the 2g and using the hubs all around, and doing a 5lug wheel. Now, I am lead to believe that the 2g rear end is not a "good thing". What is your take on using the 3bolt 1g rear, converting it to a 4bolt from the 2g rear, and use the 5lug wheels and brakes. I am after more width. I am going to cut and flare the fenders. :ANAL: :rolleyes:
PostPosted: Tue Apr 24, 2007 9:45 am
what axles am i suppose to use in the front if i am going with a 2g trans up front...
PostPosted: Mon May 07, 2007 2:28 pm
Bill from what I have gathered the 2nd gens don't use a "4bolt" rear. Its a completely different setup. Unless you feel like laying your own tracks on your swap I say sell that stuff and source up some 1g components.
PostPosted: Tue May 08, 2007 9:15 am
That is consistent with the advise I am getting. Thanks.
