If you have the distributor on the front passenger side of the cylinder head, then you have your coil inside the distributor and the transistor mechanism is inside as well.
I do. But I've had the distributor off and it doesn't look anything like my Honda distributor did inside. I know we are talking apples and oranges here but it can't be that different.
If you have an led light with resistor inline, follow the links I posted up top to get you to the diagnosis terminal (DLC) down by your left foot/fuse panel. Find the appropriate pins and put the key in the ignition. Follow the steps on either LilEvo.com or Berserko's Geocities site, and you will have strobes of the led lighting it up, like morse code; long's and shorts, and pauses. This is how you read the CEL on the cheap.
Just wondering, what size LED and what size resistor? Also what size wiring would I need to do this? This is the first time I've ever played with this car and I just want to get it running correctly. The coil that I have listed on Autozone looks like an external and it looks like it mounts somewhere. I replaced the coil on my Honda once and I know where it went but does it also go in the same place on the Mitsu distributor? As in in the upper portion of it?
