It is currently Tue Oct 21, 2025 12:53 pm
Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 178 posts ]  Go to page Previous 1 2 3 4 512 Next
PostPosted: Sun Dec 10, 2006 12:31 pm
I havent forgoten anyhting yet, the water pipe is out till i install the upper mount. And yes every part is new or reconditioned to my liking. Working at a performance machine shop has it's advantages.
A little rundown of whats in this motor
Head:
-Bronze valve guides
-3 angle valve job (sunnen VGS-20)
-Valve seats opened
-Duel angle valves
-Springs shimed .030
-Mild porting and polishing
-Milled .014
-New plugs (.024gap)
-Ported intake
-550 RC injectors
Cometic custom 4 pc headgasket .074 (stock is .054)
Block:
-Shotpeened block
-All mechining done on RMC V30 4axis CNC
-Bored by probed centers .015
-Square decked .008
-Final honing on Rotller diamond hone
-Balance shaft bearings turned to block oil holes
-New freeze plugs
Rotating assenbly:
-1g big rods reconditiond with ARP bolts then balanced small and big ends to exact same weight
-.020 Topline pistons
-.020 Total seal rings
-Over balanced crank (was 3.2/3.6 now .05/.07)
-Zero balanced flywheel (it was 14.7 grams off now .05 grams off)
-Clevite std/std bearings
Other parts:
-Apex complete gasket kit (very nice kit)
-New water pump
-New oil pump /with balance shaft stub installed
-New timming belt/tensioner
-All new timming belt pulleys
-Magnetic oil drain plug
-All reusuable parts wheres cleaned to look new by sand blaster and high temp paint
-New belts for alternator and p/s
-New thermostat
-New O2 sensor
I know I'm missing some things but you get the gist of it, this should be a nice daily driver motor.
I'll be making a nice write up when I'm ready, I have taken pictures of the entire process. This write up is still far away cause I'm going to finish the AWD first.
PostPosted: Sun Dec 10, 2006 1:49 pm
I belive the inside of the house is the best place if you dont have a temprature controlled clean room laying around. :twisted:
Adam
93'FD Touring non-seq
05'WRX
PostPosted: Tue Jan 30, 2007 11:01 am
Finished painting the rear end (looks awsome)
Ordered all misc. parts from mitsu (sway bar bushings/end links/rubber mounts)
Droped off my driveshaft this morning to be shortened he quoted me around $100.
Picked up rear axle that need a new boot installed $30
Looking into a couple local cage builders this week.
More to come
Adam
05'WRX
PostPosted: Mon Feb 05, 2007 9:22 pm
picked up the driveshaft $75
Got all misc. parts from junkyard
Looking at welders now and checking out cages.
PostPosted: Mon Feb 05, 2007 11:41 pm
You my friend. Are a baller.. Get it done.
PostPosted: Tue Feb 06, 2007 9:20 am
you have got a hole bunch of money sitting there sitting there in just machine work
PostPosted: Tue Feb 06, 2007 10:20 am
I have zero money tied up in machine work. :ANAL:
Adam
05'WRX
PostPosted: Tue Feb 06, 2007 9:44 pm
Nice to see you're still in the game!
I'm in the midst of porting a head to install on the GVR4. Where should I take it to get cleaned/decked, and reassembled?
Geoff
2013 Genesis 5.0 RSPEC
88 Mazda Turbo II- LSX7
89 2.0 Turbo Colt
13 Ducati 1199 Panigale
PostPosted: Wed Feb 07, 2007 10:31 am
my bad looked like you had a bunch in machine work
PostPosted: Wed Feb 07, 2007 10:34 am
Yes, you got it right, he works at a machine shop! 8)
PostPosted: Wed Mar 07, 2007 11:33 pm
I got the bare block and AWD tranny instaled in the Summit and it is heading up to HTP a local turner shop to have the AWD installed this week. I wanted so much to do it my-self but I dont have the three thing's I need (time,welder,lift). This was one of the only shop in the STL I would let work on my C/S/M,DSM. I will have many pics comming in the next few weeks.
Adam
05'WRX
PostPosted: Wed Mar 07, 2007 11:51 pm
So wait... I thought it was already mostly done?
PostPosted: Wed Mar 07, 2007 11:53 pm
You thought wrong I do have a Colt turbo(4g63) I drive everyday thoe.This is the new puppy
PostPosted: Thu Mar 08, 2007 2:26 am
Looking good Adam :)
