It is currently Mon Oct 27, 2025 10:33 pm
 Post subject: 4g61T front hub !?
PostPosted: Wed Feb 28, 2007 6:59 am
hey guys... i need a little help here !
hummm i have a colt 93 coupe swap 4g63T with 4g61T front disk conversion.
cuz of the new hub ( not bolt patern problem ) my 17" wont fit right.
the disk is bolted to the hub. those bolt doesnt allowed my 17" to sit right on the hub.
what would be the solution ? ( and i would like to keep my wheels since im in love with them ;) )
is there some sorta spacer / adaptor ?
or i need some wheels in particular ?
can i modif. my wheels to make it fit ?
help me plz.
thanks for the help.
p.s: sorry for the bad english...its not my first language but i try my best.
edit: here's a pix of what the wheel should look like to allowed clearence for the bolt. what my wheels doesnt have.
do you think it would be safe to use a dremel to ''grind'' those holes in my wheel then rebalance the wheels with tires on ?
the other thing that i have to worry of is the center ring. i still need to be able to easilly center the wheel.
PostPosted: Wed Feb 28, 2007 9:39 am
You can either modify the back of your wheels to clear the bolt heads or pick up some 1/4" spacers for about $10 US.
PostPosted: Wed Feb 28, 2007 5:58 pm
what would you use to modify the back of the wheels ?
where could i get those spacers ?
and with the spacer will it be still possible to use centric hub ( ring ) to center the wheels on the hub or just some tuner nuts will do ?
PostPosted: Wed Feb 28, 2007 8:49 pm
I would not recommend using spacers, especially on the front! I had my rims machined at a rim repair shop. From memory you need 4 x 10mm deep holes machined into the back of the rim with a PCD of 100mm (I think!) offset at 45'.
Unfortunately most shops require that the tyre is removed from the rim before they can machine it.
You could probably do the job yourself if you had a drill large enough but you'd want to very careful with your measuring.
PostPosted: Wed Feb 28, 2007 10:05 pm
I ran the 1/4" spacers on the front without any problems at all but honestly it would be better to mod the wheels. I picked mine up at a local wheel shop for $7 each.
PostPosted: Thu Mar 01, 2007 12:13 am
and you had no problem getting the wheel balance right after ?
no vibration at any speed when you drive ?
PostPosted: Thu Mar 01, 2007 12:19 am
and how did you center your wheel on the hub ?
PostPosted: Thu Mar 01, 2007 8:37 am
I had aftermarket wheels and tuner style lugnuts. I always tightened the wheel while it was still in the air and it always centered perfectly. Once I let it back down I then torqued them to spec. Always drove perfect, not one bit of vibration.
PostPosted: Thu Mar 01, 2007 7:23 pm
There is no problem here as the material removed from the wheel is very close to the hub centre and therefore has next to no effect on the rotating balance of the wheel.
In any case there (should) be symetrically equal amounts of material taken of the wheel and the wheel/tyre combo is balanced together. There would be more of an effect from the normal irregularities of the outer wheel rim and tyre.
PostPosted: Fri Mar 02, 2007 12:47 am
alrighty then ;) ( sorry watching ace ventura )
ill let you know what i choose to do.
thank you all.
PostPosted: Wed Mar 21, 2007 10:09 am
im sorry to bring the post up again...but i think i found the needed spacer ... i just want to be sure that will do.
http://cgi.ebay.com/ebaymotors/Wheel-Sp ... 0096674094
8mm ( 5/16 ) in thickness...4x114.3 compatible...those spacer + tuner lug nut will do the job i think.
tell me what ya think !
PostPosted: Wed Mar 21, 2007 4:35 pm
They should work if you want to go that way.
I used a dremel tool on the back of my rims, just got to keep the bit cool with some coolant (antifreeze should work), this stops the bit from plugging up. I never had a problem with centering or changing the balance.
- Works in da bush
PostPosted: Wed Mar 21, 2007 4:47 pm
ok...i think for the price ill try the spacer...i dont want to messed up my wheels aspecially that i plan on been 5 bolts all around...im gonna need to sell those wheels...
thanks guys
