It is currently Thu Oct 30, 2025 10:08 am
PostPosted: Sun Oct 01, 2006 10:34 pm
I was wondering if you guys know if it is possible to do a 4G63t into a non-mitsu car without to much fabrication?Would I need the FWD frontend?
P.S Its a Toyota with the 1zz
PostPosted: Sun Oct 01, 2006 10:50 pm
Remember: anything is possible, but not everything is cool.
-bit
PostPosted: Sun Oct 01, 2006 11:29 pm
Remember: anything is possible, if you have money.
-bit
Fixed.
:lol:
PostPosted: Mon Oct 02, 2006 12:25 am
It's not even money, it's just brains. You can buy an entire beat 1g for a few hundred dollars, everything you'd really need would be there.
What's a 1zz motor? You mean 1jz? There's some bad ass Toyota engines out there that could possibly swap in, don't bother with Mitsu junk.
PostPosted: Mon Oct 02, 2006 12:39 am
The 1ZZ-FE is a Toyota Celica GT motor. It was also used in Corollas and the MR-S Spyders. There's nothing special about that motor though, I think it makes like 140hp. If he's talking about putting a 4G63 in an MR-S I think that would be a retarded idea, and I'd definitely go for a 3S-GTE swap before swapping in a Mitsu motor and going through all that work. :hmph:
PostPosted: Mon Oct 02, 2006 3:53 am
A 4G63 turbo and tranny have already been installed in a 1st gen MR2, so anythings possible.
The bigger issue is knowing what you are getting into.
If you HAVE to ask that question then the answer is NO. There is no
cross swap that will be easy and without much fabrication for YOU if you had to take the time to ask if it would it be easy or not.
What type of experience /money/tools do you have? Not that you have to publicly answer on this thread, but they are variables to take into consideration of you want to do a swap.
1. How will I mount this motor in the chassis?
2. Who will build the motor mounts and how much will they charge me if I'm not going to do the welding
3. Am I going to use a COMPLETE 4G63 wiring harness, or build a custom harness
4. How about my axles..... Do I go with shorthened/lengthened, beefed up axles, and how much will they charge me to mod them?
5. what radiator am I going to use?
There are probably 100 other questions that I could ask but you get the picture.
Geoff
2013 Genesis 5.0 RSPEC
88 Mazda Turbo II- LSX7
89 2.0 Turbo Colt
13 Ducati 1199 Panigale
PostPosted: Mon Oct 02, 2006 3:55 am
Bingo. I wish I could post this in about 100 threads a years, but most forums would ban me.
PostPosted: Mon Oct 02, 2006 7:48 pm
ok,my experience is not very good,but my dad has 30+ years,i have tools galore and its a toyota corolla,the reason i want a 4g63t instead of a 3sgte is that a mr2 clip costs me 4k+ and oi can get a decent condition dsm with 1k
PostPosted: Mon Oct 02, 2006 8:53 pm
If you have a Corolla like that WHY would you want to completely destory the car's purpose in life by installing a 4G63 into it? The Corolla is the ultimate reliable daily-driver man, that's it's intended use on this planet, don't go messing with that. If you want a 4G63 so bad then go out and buy a DSM! You've already got a reliable daily driver, so that will make owning a DSM that much more fufilling.
Swapping a 4G63 into a FWD Corolla would be insanely difficult, even though your Dad has all this experience at his fingertips, do you really think he wants to take on a project like that? You'd have to fab mounts, find some sort of axle combination that works, do tons and tons of wiring to make the ECU jive with the rest of the car, and so on and so forth. Forgive me for being so blunt, but it's a retarded idea.
PostPosted: Mon Oct 02, 2006 10:33 pm
AMEN! :D
PostPosted: Thu Oct 19, 2006 2:17 am
couldnt the same be said about a stock dodge colt.. ????
if everyone had that mentality this forum wouldnt exist..
lancericgsr: if you have enough experience with the DSM cars you can pull it off.. but im sure it wont be cheap. almost everything about the project will be custom. that includes motor mounts,axles,shift cables,fuel lines and pump, throttle cable, radiator and hoses, wiring, intercooler pipes and core mounting, etc etc. but nothing is impossible, the 4g has been swapped into every kind of vehicle imaginable, from starions, to jeeps to rx7's to cavaliers... christ i bet right now someone is taking measurements for fitment into a snowblower.. :)
good luck if you try it.. !! if not.. i understand :)
PostPosted: Thu Oct 19, 2006 7:25 am
It would be easier to swap into a mirage, then put corolla body panels on the mirage trying to make it look like one. :lol:
If it was some unique swap, it would be a sweet idea. Unless you're "in the know" like everyone on this forum, 99/100 people in the real world think a corolla and a 4 door csm is the same car.
PostPosted: Tue Nov 14, 2006 3:05 am
abnormal
yes it could be said about a stock dodge colt but the colt is within the same platform...corolla you'd be customizing every aspect of it...and how about this I'll trade u my 92 dodge colt along with the parts to do the 5spd swap to it for ur corolla? ;-) if the rolla runs drives and will make it to florida
PostPosted: Tue Nov 14, 2006 3:45 am
isnt that what i said?
i dont need a new car and dont have a corolla. I wasnt saying i would do it, and i know the colt is the same platform. i was commenting on how people with opinions sway other peoples decisions based on what their opinion of what cool is or whats worth it. I see the same thing with alot of the car community. people say, "why do that, when this is cooler, or easier" and then when someone doesnt ask for opinions and just goes out and makes shit happen, everybody oohs and ahhhs.. example.. 4g63 powered mighty max.. or 4g63 powered porsche. or 4g63 powered starion. or the 4g powered honda on ebay right now. do you think he let other peoples opinions sway his decision on the kind of car he wanted to build? dont you think that alot of people said, "why do that when the b16 swap is way easier?"
If say like 10 years ago someone came on a car forum and said i wanna put a talon motor in my mighty max truck, they would get laughed off the forum..
i've been around long enough to know that in the car world everyone has opinions, but the people who build the coolest shit didnt ask for everybody elses opinion they just do it.
PostPosted: Tue Nov 14, 2006 4:41 am
abnormal
not u retard there was a reason i put "..." then continued on, but umm the 63 powered porsche is retarded it'd be cheaper then buying a whole new porsche motor tho so it's within reason, starion is mitsubishi platform DUH!, mighty max mitsubishi platform, honda just kinda retarded but hey if it's how u make a honda fast. lol j/k and seriously why would u do that if something else is easier and cheaper in the long run he asked
"I was wondering if you guys know if it is possible to do a 4G63t into a non-mitsu car without to much fabrication?Would I need the FWD frontend?
P.S Its a Toyota with the 1zz " they answered him with blunt responses get over it EVERY ASPECT WOULD HAVE TO BE FABRICATED IS WHAT THE MEMBERS HERE AT 61T ARE TRYIN TO TELL HIM....No u can't see that tho
lancericgsr you came to the right place to ask the questions but unfortunately everything would need to be fabricated pretty much...but i'm open to trading lol
