It is currently Fri Jun 07, 2024 12:34 am
PostPosted: Tue Feb 07, 2006 7:54 am
I raced my roommate's RB20det-powered S13 coupe over a month ago.
I walked away from him a couple times from a ~35mph roll.
Here's what he's runnin:
RB20DET
huge FMIC
Greddy eManage
Blitz electronic boost controller @15psi
3" downpipe and exhaust
HKS intake
Spec stage 3 clutch
Fidanza flywheel
SSR forged 16x7 and 16x8 Integral A2 w/225/40-16 Toyo Proxes T1S
HKS drift spec coilovers
various Cusco bars
Here's what it looks like (and what my car used to look like in the background:
1989 Mirage Turbo w/4G63T
1991 Mazda MX-5 (UK spec)
2018 Hyundai I30N
PostPosted: Tue Feb 07, 2006 8:29 am
Good sh*t Scott!
Be careful though. Bigger rear tires, more PSI and bigger Cajones means he'll get your @$$ sooner or later. That RB motor is a beeeyotch when it has the right parts :o
Geoff
2013 Genesis 5.0 RSPEC
88 Mazda Turbo II- LSX7
89 2.0 Turbo Colt
13 Ducati 1199 Panigale
PostPosted: Tue Feb 07, 2006 10:38 am
omg! i want little ninja's protecting my car too! :D awesome! 8)
PostPosted: Tue Feb 07, 2006 11:41 am
Good sh*t Scott!
TRUE! But I'm not worried. His stock turbo is dying a slow death. Plus, by the time he's upgraded, I will have, too. I've finally decided to go fmic (only due to tire clearance issues), and I'll soon have not only much better piping, but a better flowing head. Cams, too. Then it'll be time for a bigger turbo.
2018 Hyundai I30N
PostPosted: Tue Feb 07, 2006 1:05 pm
You forgot to post this, he forgot to paint the front of his car. Like a match made in heaven. :partyman:
PostPosted: Tue Feb 07, 2006 4:14 pm
Car looks super hot. But i most ask if that is his first Spec clutch? My friend has ran them in his Bluebird(SR20DET) powered NX2000 and he blow them to pieces without even pushing that much power.
89' Mitsubishi Mirage Turbo.
PostPosted: Tue Feb 07, 2006 9:26 pm
Yeah, it's his first. He doesn't really do any hard drag launches though...so it's lasted him a while. Also, it's a stage 3, so it should be able to stand up to a lot of abuse.
2018 Hyundai I30N
PostPosted: Tue Feb 07, 2006 9:34 pm
1595 cc's of fury
RB20DET.....
I believe your refering to an 'RB25DET'...its a 6 cylinder correct?
PostPosted: Tue Feb 07, 2006 10:46 pm
my old 240 used to look like that. except i dont have thoes wheels. same front end, same color, same front end color, and etc.....i kind of missed it. that thing was going to be a 8 speaker project car
PostPosted: Wed Feb 08, 2006 5:39 am
RB20DET.....
Negative. It's a 2.0L straight six, called RB20DET. Related to the RB25/26 though. Stock it's about 200hp. He's dynoed at over 230rwhp. Forgot to mention he has LSD too.
And I just talked to him....turns out he's getting a bigger turbo with his tax refund. DAMNIT! So I'll probably be outclassed for a while. Oh well.
2018 Hyundai I30N
PostPosted: Wed Feb 08, 2006 6:09 am
www.rb20det.com
RB20DET specs:
No. and arrangement of cylinders = 6, in-line, vertical
Combustion chamber type = Hemi-spherical
Valve arrangement = Overhead valve type
Camshaft arrangement = Double Overhead Camshaft
Total displacement cc = 1998cc
Bore x Stroke mm = 78.0 x 69.7
Compression = 8.5:1
Bhp = 214bhp at 6600rpm at flywheel
Geoff
89 2.0 Turbo Colt
PostPosted: Wed Feb 08, 2006 2:39 pm
Nice kill dude. You don't see many S13's with that swap; in fact, i've never seen one before. Very cool. That's a neat little motor I must admit, looks like it could be set up to be quite the revver. Needs more video. :wink:
PostPosted: Wed Feb 08, 2006 3:24 pm
Yeah, it's definitely a sweet motor. I can't wait til he goes with a bigger turbo. He's got ARP head studs, and a strong headgasket, plus a GT-R fuel pump and injectors, ready to go. Oddly enough, there are several RB20-powered 240s here in Augusta. RBs are really cheap now (complete motor sets going for <$1000). All you need is a set of custom motor mounts, and a custom downpipe (both can be found online now). BUT, the SR20 is still better IMO...because the RB w/tranny is something like 150lbs heavier than the SR w/tranny!
I'm going to try to find some videos of the car. My roomate is one hell of a drifter, so I'm sure there's some floating around of him slidin that mofo.
2018 Hyundai I30N
PostPosted: Wed Feb 08, 2006 5:10 pm
Makes sense, the RB is probably iron block where-as the SR20 is all aluminum. In someplace like Georgia I'd probably opt for the RB swap, because smogging the car isn't really an issue. Out here in Cali you have to beware of smog nazis wherever you go, it sucks. :-?
PostPosted: Thu Feb 09, 2006 7:29 pm
1595 cc's of fury
Odd, I knew there were rb20det's. I always assumed it was a 4 cylinder version of the rb25/rb26. That thing would be a real rev'er with a larger turbo and some cam's. Good kill anyhow.
