It is currently Sun Oct 26, 2025 9:36 am
 Post subject: i did it
PostPosted: Fri Nov 04, 2005 8:57 am
i successfully made a 25 gallon batch of biodiesel in my processor.. would of been 35 but we messed up somewhere and had a lil spill.. but still it only cost 20$ to make 35 gallons.. i dont have my diesel golf yet but its going to be used in my friends fathers trucks refirgerated trailers.
PostPosted: Fri Nov 04, 2005 10:24 am
Nobody Important
Impressive!
Any more details? What did you start out with? How long did it take? Will it run in an unmodified modern motor?
-paul
PostPosted: Fri Nov 04, 2005 12:44 pm
ill tell you how it happened
we loaded the processer and heated to 130 degrees on 110 volts ( the element in it is a 220 volt element so it takes 4 times as long to heat) it took 3 hours to heat
after that we added the methoxide 7 gallons of methanol to the determined amount of catalyst ( sodium hydroxide) we determine the amount through titration
we added the methoxide and allowed to circulate for 2 hours. then settled over night but you can let settle for 3 hours and be fine..
drained off the glycerine into a drum.. encountered a problem me and my friend had slight methanol poisoning for the day we thought the vent hood was good enough for us as it was used for welding..
we drained the unwashed bio into the wash tank we had a little accident.. forgot to open a valve after we checked something so the line blew off and we lost maybe 3 gallons..
we washed with a garden hose on the shower function.. no emulsions at all took 5 washes to get the wash water crystal clear
drained all the water out we could and let it bubble wash over the weekend.. one night of bubble drying or polishing is good as long as your sample you pull is clear enough to read news print through
i sold 5 gallons to some one starting up their processor.. we ran a b60 blend in his 81 rabbit pickup truck diesel of course.. it quieted down ran cleaner smoother and the exhaust had a different smell .. not like french fries ( if it smells like the stuff the oil was coking in then you have a problem with conversion) but it smelled a whole lot cleaner
his truck is fine still running on the same fullup
hes keeping an extra filter and some diesel in a bottle so incase he has to change filters he will be ok
total time for processing and washing if i do it during the week for 35 gallons.. id say around 24 hours.
costs for 35 gallons to make it.. 22.17$
price a gallon .. around 1.12 ( we ended up with 25 mishaps and all) but conpared to reg diesel in my area 3.00 its still considerbly cheaper
yes paul it will run in an unmoded engine if you have a 93 or newer car pre 93 natular rubber lines were used and those degrade..
the leader of my coop has a 02 TDI golf with stage 3 turbo and he smokes regular TDI's on B100 he also has a 95 dodge cummins WVO powered truck
PostPosted: Wed Nov 09, 2005 9:31 am
This is fantastic, any pics of that reactor? 8)
Got rabies?
 Post subject: Re: i did it
PostPosted: Wed Nov 09, 2005 1:35 pm
sweet...i just found a local restaurant that will sponsor me with some grease thats usable.
After the colt project I wanna start project Turbogreasel on my 86Golf :finga:
91EclipseGST.Heart Transplant
89ColtGL - 4G63T Rebuild Soon
PortedEVO3.16G.Ported1G02.HKS.UICP.255lph.
PostPosted: Wed Nov 09, 2005 4:43 pm
Vendor
Good job man! Ill give a cookie to the first person who converts a colt over to diesel :P
Hybrid Connection
2756 Transit Road
West Seneca, NY 14224
716-674-2772
In Hybrid We Trust
PostPosted: Wed Nov 09, 2005 6:55 pm
Mitsu already did that. See here:
4D65. As simple as that. ;)
2000. Hyundai Sonata EF 2.0 (Hyundai version of 4G63 and F5M22)
1991. Mitsubishi Lancer C62 1.5 (4G15, F5M21)
PostPosted: Wed Nov 09, 2005 11:17 pm
What did they NOT put in a Colt?!?
04' Olds Alero
91' Colt GL hatchback
4g15 12valve 5spd.
Lots of little s#@t
PostPosted: Wed Nov 09, 2005 11:25 pm
They did... In europe and eastern block countries...
LC '01 Accent GSI - Silver
PostPosted: Fri Nov 11, 2005 4:14 pm
i rember i had the weird idea of putting a golf diesel engine i could get into my colt.. hey people in the fl tampa area their is a 77 rabbit diesel parts car with running motor a know about and a 600$ plymoth colt i know about.. put them together and have fun... reactor pics sure thing
its in my high school shop...
aaaannnd a pic of the car im picking up sunday sorry not my pic but owners
PostPosted: Mon Nov 14, 2005 6:37 am
That reactor looks simple enough for me to try to create one myself. :D
Got rabies?
PostPosted: Mon Nov 14, 2005 6:09 pm
i belive some people are doing it in germany already .. check out biodieselnow.com for regional forums and biodieselcommunity.org for info on how to make a processor and to make biodiesel plus they have a forum
