It is currently Mon Oct 20, 2025 12:52 pm
PostPosted: Fri Oct 21, 2005 10:47 am
hi my name is greer
im 25,i live in Auckland,New Zealand (land of the long white cloud and home of the all blacks rugby team)
my car......
1988 mitsubishi lancer GSR (jap spec) c63a 4g61t fwd
i picked this car up about 6months ago in standard form,274000 kms on the clock, cost me $1000 nz dollars
so then the modding started.............
2 1/2in exhaust from turbo straight through (no resonators) to stainless steel muffler, td04l turbo off a 1994 mitsy lancer gsr cd5a 4g93t (jap spec)
fitted with a screamer pipe, k&n air filter, ngk spark plugs (bp7es), top gun 8.8mm racing ht leads, fmic off a 98 lancer evo 5 cp9a (jap spec) with
custom ic piping, custom 3in intake pipe to turbo, 89 galant vr-4 4g63t e39a (jap spec)-air flow meter-injectors-throttle body.
suspension is factory kyb shocks,lowered 40mm with b&g springs,17in x 7in enkei tarmac evo wheels with 215/45/17 tyres,heavy duty front and rear brake pads
the car was going very well with these mods but that was not enough for me,so then came.........
td05h 14g turbo and exhaust manifold off a e39a vr-4, sard fuel pressure regulator,gizzmo eletronic launch controller, gizzmo chipped computer "md128618" off a e39a vr-4......i picked the car up from the workshop and was driving around when i decided to go on the motorway for a test....3rd foot flat was going the fastest it had been yet, i saw the boost go up to 20psi then boommmmmmm!!!!!!!!!!!! it was all over blown motor,it died at 278???kms.......
so now i have pulled the motor out (lucky i had a spare motor sitting in my garage at home which had been there for about 4years from a 1991 mitsy lancer gsr c73a it had about 110???kms).........so i have put that in now with a few more mods......trr extractors with tial 38mm external wastegate,new high flow fuel pump,i got a few things painted blue and some other parts polished........still not running yet
gear box is km210,with standard clutch
have not run this car on the 1/4m yet but wont be long now
here are some pics
engine
http://photobucket.com/albums/a380/nfam ... dcp006.jpg
http://photobucket.com/albums/a380/nfam ... dcp005.jpg
http://photobucket.com/albums/a380/nfam ... dcp004.jpg
thecar
http://photobucket.com/albums/a380/nfam ... dcp002.jpg
speedo
http://photobucket.com/albums/a380/nfam ... 005018.jpg
door mouldings
http://photobucket.com/albums/a380/nfam ... 005017.jpg
rims
http://photobucket.com/albums/a380/nfam ... dcp009.jpg
the car
http://photobucket.com/albums/a380/nfam ... 05_006.jpg
muffler
http://photobucket.com/albums/a380/nfam ... dcp003.jpg
8) 8) 8)
c53a mirage cyborg 4g61t fwd 184kw atw on 16psi 14.028@179kmh not much traction
c63a lancer gsr 4g61t fwd (almost finished)
e39a eterna zr-4 4g63t needs fixing(engine)
s13 silvia ca18det 182kw atw on 0.6bar now waiting for panelbeating
Image Image
PostPosted: Fri Oct 21, 2005 4:10 pm
You weren't kidding about the blue, I think I'm depressed now. Looks good.
:D
PostPosted: Sat Oct 22, 2005 4:00 am
:D thanks i have too much spare time!! :lol:
Image Image
PostPosted: Sat Oct 22, 2005 5:14 am
here is my gf's car it is 1990 c53a mirage 4g61t fwd
it has similar mods with my car, had this car for 4yrs and have been doing it up for a while and its not too bad
184kw atw on 16psi
14.028@179kmh at champion dragway on street tyres too much wheelspin
gearbox is f5m22
here the pix.............
me at the drags
http://photobucket.com/albums/a380/nfam ... mall14.jpg
http://photobucket.com/albums/a380/nfam ... _sp013.jpg
http://photobucket.com/albums/a380/nfam ... _sp014.jpg
engine
http://photobucket.com/albums/a380/nfam ... 1Small.jpg
http://photobucket.com/albums/a380/nfam ... 2Small.jpg
http://photobucket.com/albums/a380/nfam ... -Small.jpg
http://photobucket.com/albums/a380/nfam ... 4Small.jpg
http://photobucket.com/albums/a380/nfam ... 005006.jpg
http://photobucket.com/albums/a380/nfam ... 005008.jpg
the rims
http://photobucket.com/albums/a380/nfam ... 005001.jpg
Image Image
PostPosted: Sat Oct 22, 2005 6:44 am
Sup biarch :lol:
PostPosted: Sun Oct 23, 2005 1:33 pm
here is my other toy for doing some driftys
1989 nissan silvia s13 5spd man,5spd manual,ca18det,garrett t28 turbo,extractors with trr 40mm extrenal wastegate,blitz fmic,custom piping,custom induction pipe to turbo 3in,hks bov,dragsport air filter,malpassi fuel press reg,chipped computer,3in exhaust,heavy duty race clutch,light weight flywheel,lsd diff,adjustable coil overs
182kw atw on 0.6bar + more to come.......................
the car
http://photobucket.com/albums/a380/nfam ... silvia.jpg
burn outs
http://photobucket.com/albums/a380/nfam ... t=MF35.jpg
http://photobucket.com/albums/a380/nfam ... t=MF36.jpg
http://photobucket.com/albums/a380/nfam ... t=MF37.jpg
http://photobucket.com/albums/a380/nfam ... t=MF38.jpg
then there is a silence
http://photobucket.com/albums/a380/nfam ... tacked.jpg
stay tuned right here................... 8) :supz: :wall:
Image Image
