It is currently Mon Oct 20, 2025 4:56 am
Post new topic  Reply to topic  [ 59 posts ]  Go to page Previous 1 2 3 4
PostPosted: Wed Jan 07, 2009 1:30 pm
I realized after doing a lot of reading that I wasnt going to be able to do my fuel setup the way I wanted for a cheap price, instead of half my fuel setup to just barely be able to make 700 on gas, I took the alternate route of being able that and than some on E85. Instead of running an inline 044 I have opted to run 2 in take 255LPH fuel pumps. and to maximize efficency, run -6 out of the tank, and Y it into -8 after the pumps are out of the tank.
I ordered 2 -6 bulkheads, along with 2 straight -6 pushlock fittings to go INSIDE the tank, the 255's take 5/16's line, but i will boil the line in some hot water to get it to slip over the -6 straight fittings( just to get the fuel line to work with the 255's)
Coming up out of the tank I am going to run 2 -6 90 pushlock fittings and run a couple feet of the -6 line where I will Y it into the -8 Line.
Here is a picture of the 2 bulkheads with the 2 straight/ 2 90 fittings connected.
and a picture of the fitting taking the 2-6 lines and running them to a single -8... the dual -6 to single -8 wasn't cheap.
From their I will take the Single -8 Line and run it to a -8 inline fuel filter, I havent purchased the filter yet but I did purchase the 2 -8 straight fittings.
and from the fuel filter to the rail I am going to weld a -8 weld fitting to the Fuel rail on the feed side, connected with 45 degree -8 pushlock fitting
I'm going to run a -6 weld fitting off the other side of the rail that is going to go to my Fuel pressure regulator, and from there I'm going to return the fuel to the tank via the stock return line.
thats about it for my fuel setup.
PostPosted: Wed Jan 07, 2009 2:37 pm
I honestly don't think the stock return line will be able to return that much fuel with dual 255 pumps. But I don't have any experience with that, but most usually upgrade the return line also. Just thought I'd point that out.
PostPosted: Wed Jan 07, 2009 3:49 pm
sorry, I need to go back and edit my post. The dual 255's will not be run by the stock return line, they are going to be returned VIA the stock FEED line.
Andrew
PostPosted: Wed Jan 07, 2009 8:25 pm
Thats how mine is hooked up also, Im using the stock Feed line as my return.
PostPosted: Thu Jan 08, 2009 12:34 pm
You guys have already seen most these pics but I had a buddy stop over with a d-slr and take some photos, turned out pretty well, here are a couple of the good pics
hope ya enjoy
PostPosted: Sun Jan 11, 2009 9:18 am
Sweet man, so I was wondering... did you get a good deal on that turbo? Or how come you didn't go with a BB turbo or even a GT40R instead? Thanks for any input... :) By the way, the car is going to be sick when done! :D
PostPosted: Sun Jan 11, 2009 12:52 pm
I picked the gt4202 up for a couple reasons, the spool between the 4202R and a standard bearing 4202 isnt justifiable by me to spend the extra money on... that and I simply got a good deal on the turbo from Jake montgomery. I deffinately think the car is going to be pretty badass when done. the motor was put in last night and now its time to start making that engine bay look nice.
Andrew.
PostPosted: Mon Jan 12, 2009 12:09 am
Andrew.
Lets see some pics,lol. :wink:
PostPosted: Mon Jan 12, 2009 4:06 am
what intake plenum are you running in there? should make for a interesting street car (will be one hell of a sleeper) i ran a factory 4g61 n/a fwd box on a worked 4g63t vr4 motor (was around 380-400hp) and never had a issue with it over 2years of running the setup, with a 5puk clutch so was pretty roug between gears bt never gave out. so anythings possible, you dont know untill you try at least
PostPosted: Mon Jan 12, 2009 12:38 pm
The motor went in without a hitch... threw on the clutch/flywheel with everything else and jammed it into the engine bay. instead of a chain I didnt want to scratch all the bling bling up so I settled for a couple nylon straps a couple used shirts and some masking tape to keep everything pretty.
Now will come the hard part of tucking everything away and hiding it nicely :)
she decided it was a good time to sleep the night away..
with some weight on the front end, it tucks the tires nicely.
Andrew
PostPosted: Mon Jan 12, 2009 1:14 pm
Pure sex! keep it coming 8)
PostPosted: Mon Jan 12, 2009 6:46 pm
:o , looks good man, it would be a better idea to put those things after the motor is in so you would mess up the bling bling :wink: , just a thought, because I did the same thing and did mess up my bling bling on my old 2g fwd,lol.
PostPosted: Thu Jan 15, 2009 9:07 pm
Seen this car on link forums, great build
PostPosted: Fri Jan 16, 2009 6:56 pm
I like the setup, the color is...... :barney:
