It is currently Sat Oct 25, 2025 9:19 am
 Post subject: Tacho not working at all
PostPosted: Mon Feb 07, 2011 3:26 am
Hi All,
my tacho meter is not working. i've changed the noise filter as well as the transistor (which sits behind the IM) but nothing worked for me. i need to make it work asap, please help.
PS:its a 4g63t colt
Thanks.
Mitsubishi Colt '90-With a AWD 4g63t swap (VR4-RS) 1g 6-bolt motor
DSMLink,AFPR,FMIC,609,750RC, HX35, ARP, MLS, BC S&R, Crower 272s, Gates belt.
PostPosted: Mon Feb 07, 2011 10:27 am
has it ever worked? Is this a swapped car? are you running a 90 DSM tach filter?
PostPosted: Mon Feb 07, 2011 12:35 pm
yes it use to work, its a swapped car.
90 with filter as in the sticky.
infact i just checked the connectivity to the white wire, its there but for some reason its not working. what do check now? i'm stumped.
PostPosted: Mon Feb 07, 2011 12:49 pm
try another tach if you have access to one. I got lucky on my third tach, the first two did not work.
PostPosted: Mon Feb 07, 2011 1:08 pm
:( i dont have one
can i install after market tacho meter? if yes then how?
