It is currently Thu Oct 30, 2025 5:52 pm
PostPosted: Thu Jan 04, 2007 11:54 am
I'm having issues getting the passenger side axle to stay in place. Can anyone help me out?
89' Mirage Turbo
My hatch is better than yours
PostPosted: Thu Jan 04, 2007 1:31 pm
try a welder.. or give us more info on what its doing? either way works great
PostPosted: Thu Jan 04, 2007 2:27 pm
I am assumimng you are trying to put a non-equal lenght half shaft into a AWD trans. I am pretty sure that the AWD side gear does not have a groove cut into it to catch the C-clip. You will need to run the two piece half shaft(equal lenght). I also got a trick from PTTcolt that to bolt the halfshaft to the back of the block without the A/C plate that goes under it. Use two 6bolt head bolt washers under each bolt (4 total). Worked great in my car for a year.
89 Colt GT, T4 T61, 2.0L, .
PostPosted: Thu Jan 04, 2007 3:13 pm
It pops out of the transmission constantly? I have 1G and 2G AWD trannies in my car and never had any problems with an 89 Mirage Turbo passenger axle. I had a problem of it constantly popping out and I believe it was due to not having a 1.6L turbo axle. See my "4G63 Swap" link on my webpage, at the bottom. Shows the axle differences.
What problem are you having?
PostPosted: Thu Jan 04, 2007 9:26 pm
If you need the equal length halfshaft assembly let me know cause i just pulled them. They look to be remanufactured too :o
-bit
PostPosted: Fri Jan 05, 2007 4:09 pm
Its working now, I think hopefully it wont pop out:/
89' Mirage Turbo
PostPosted: Wed Jan 10, 2007 5:34 pm
Equal length 1G is for the drivers side.
He is referring to the passenger side and should use the 1.6T axle on
that side
Geoff
2013 Genesis 5.0 RSPEC
88 Mazda Turbo II- LSX7
89 2.0 Turbo Colt
13 Ducati 1199 Panigale
PostPosted: Wed Jan 10, 2007 5:36 pm
Is it a 1.6T axle? There should be no reason why the axle would pop out of the hub assembly or tranny. Is the axle popping out of its' cups?
Geoff
89 2.0 Turbo Colt
PostPosted: Wed Jan 10, 2007 9:34 pm
I got both axles in, but theyre both 4g61t axles should I expect problems
89' Mirage Turbo
