It is currently Wed Oct 29, 2025 7:23 am
Post new topic  Reply to topic  [ 124 posts ]  Go to page 1 2 3 4 59 Next
 Post subject: 5 lug swap
PostPosted: Mon Apr 04, 2011 10:24 am
Fastest On The Site
I searched through here and only found a couple threads that were close to what I am looking for, I know this has been talked about, time and time again, but here I go asking:(
I want non captured rotors, 5 lug and bigger brakes that will still fit in a 15in wheel. I have gvr4 complete knuckles with hub and bearing and rotor. But I am now wanting to go to larger brakes for the trap speeds and crappy wheel bearing design and price! Just doing it in the front because I will be going through wheel bearing more quickly with the new wheels I will be installing on it soon. I am planning on running 25x10.5 slicks or something close to that size, so I need to make fender room which I am working on doing without putting some sick ass bushwacker fender flares on it;) :supz: So to do so I will be running a nice big offset and width wheel, thus the wheel bearing load will be greatly increased.
What are all the options? I know the Expo knuckles, DSM knuckles, etc... But I want the least amount of headache and machining. With the dsm knuckles you just need to remachine the tierod end of the knuckle to the other side right? then I could run the DSM hub, bearing, knuckles and what not.
~Jared, owner and operator of The Black Widow
10.24 @ 142.86, 1.58 60'
http://www.JayRacing.com
 Post subject: Re: 5 lug swap
PostPosted: Mon Apr 04, 2011 11:21 am
92-95 expo knuckles, 1g 5 lug dsm hubs, 93+awd dsm 276mm front rotors, twin piston calipers. This will barely clear a 15" wheel.
These will actually still use the same 1 piece sealed wheel bearing that your current GVR4 knuckles use, not sure why you call that a crappy design.
PostPosted: Mon Apr 04, 2011 11:58 am
Keep in mind GVR4 calipers are hefty pieces of cast iron. If you can afford to do so you should look into Wilwood, Project u or whatever other lightweight caliper you can find.
PostPosted: Mon Apr 04, 2011 12:06 pm
Fastest On The Site
Whoops, I mean I have the stock GT brakes. Have the gvr4 at home because I wanted to put them on originally.
What are the pros and cons between them all?
The DSM aren't captured though are they??
PostPosted: Mon Apr 04, 2011 12:19 pm
The stock GT brakes are lighter than GVR4 brakes but will not perform anywhere near as well. If you are currently using the base model brakes then upgrading to the GT brakes with a non-captive spindle will stop better and weigh right around where you were with the captive bits.
PostPosted: Thu Apr 07, 2011 10:51 am
Fastest On The Site
I am wanting to put the 5 lug stuff together soon. So I can buy some wheels and slicks as the race season is started!!
PostPosted: Thu Apr 07, 2011 10:54 am
If you ream out the tie rod end hole on the GVR4 or DSM knuckles so that you can flip the tie rod end around I'm pretty sure this makes them pretty much the same as the expo knuckles.
The dsm hubs are not captive, they provide a smooth mounting surface for the rotor/wheel.
PostPosted: Sun Apr 10, 2011 2:00 pm
Fastest On The Site
Ok thanks! So don't one of those cause extreme negative camber? Is this able to compensate thre lough camber plates?
So the Expo ones dont need to be machined to fit the tie rod?
I want the least amount of machining and fabricating. I will buy the camber plates no problem.
Thanks!
PostPosted: Sun Apr 10, 2011 2:43 pm
Tie rods fit the expo knuckles perfectly. You will need to slot the upper holes on the struts though to get some camber adjustment. Look in the archives for Coltsfan's writeup. He hs detailed pics and everything.
PostPosted: Sun Apr 10, 2011 3:31 pm
will these work instead of reaming out the top strut hole?
http://www.dsmparts.com/customer/produc ... stseller=Y
PostPosted: Sun Apr 10, 2011 3:35 pm
Probably not. Reaming out the mounts on the struts is so easy and free.
PostPosted: Sun Apr 10, 2011 3:42 pm
I allready have them thats why I asked
PostPosted: Sun Apr 10, 2011 3:59 pm
AHHH I see. I don't think they will offset the change in camber enough. But if you try it and it does work you will be a CSM hero.
PostPosted: Sun Apr 10, 2011 4:39 pm
well I have the full dsm hub,spindle and brake setup.. so I will definatly post it up as a yes or no..
PostPosted: Mon Apr 11, 2011 3:53 pm
Fastest On The Site
is the Expo 5 lug?
I also need the larger brakes which is why the dsm is attractive...
