It is currently Mon Oct 27, 2025 1:37 am
PostPosted: Sat Oct 21, 2006 12:15 pm
hey there.
Iwas thinking about get a Megasquirt, but since I dont know anything about that, I really need your help.
I tried to read everything, but still have questions.
exactly how this thing works? it doesnt matter if I have a 4g15 8v or 12v or 4g15 with 4g37 ecu, maf, inyectors?
it only works with MAP ?
how hard is install this?
how hard is tunning with this?
what exactly should I kknow before buy it.
what is the price? i couldnt find any price..........
sorry for all the questions.
thanks
Stock Sucks...!!
Mods List:
Custom cold air intake
Iridium Sparks
NGK sparks plugs wires
2" exhaust and moffler
ACCEL Coil
240cc inyectors
52mm TB
K&N filter
Elantra BRAKES ( upgrade )
195/50 R15
2.5" lowering springs
Ate. brake Fluid
 Post subject: MS Info
PostPosted: Sat Oct 21, 2006 1:39 pm
Checkout http://www.msefi.com for a foum full of information and http://www.megasquirt.info list item 7 and follow the links provided. I think RS Autosport is the way to go with labeled wires for ease of installation, but there are quite a few choices. Do your research first. You'll be happy in the end. That one of the next things I'm going to do to my Eclipse.
Ahh....VTEC: All of the lag none of the turbo. Its like waiting for bad sex.
PostPosted: Sat Oct 21, 2006 9:24 pm
I already start to read. thanks
what exactly are the parts I have to buy?
it is worth save the money and put all the parts together by myself?
Stock Sucks...!!
Mods List:
Iridium Sparks
ACCEL Coil
240cc inyectors
52mm TB
K&N filter
195/50 R15
Ate. brake Fluid
PostPosted: Sat Oct 21, 2006 10:09 pm
The kit comes with a parts list or parts if you choose to buy it that way. I would go with the assembled unit. Myself I have the skill to do it myself, but would rather have a tested positive working unit. That eliminates one variable in the overall assembly equation. :D
EDIT: You could also go with a wasted spark ignition. The megajoltis a great addition to the system.
PostPosted: Sun Oct 22, 2006 10:10 am
I just realized I didn't answer all your questions. So I'll try at it again for later readers.
You could use it on a BS engine up to any un-godly size motor. I can't remember the cylinder limit.
Yep, and that's the way you want it. Think about it this way with a MAP you can vent your popoff to atmo because the MAP knows the truth. With a MAF you can't because it doesn't know what's happening behind it. I ran into that problem a month back. My car was running horrible all of a sudden and my AFR gauge was telling me a lean condition. Running codes it said O2, MAF, and a few other things. I changed the O2 and no change. Chnage the FPR and no change. Changed the pump with a considerably larger pump(twist my arm) and no change. Started to change the MAF with one from an ole turbo clipse when I decided to take a break from it. I was smoking a stoggy when I looked at my intake air charge pipe on the floor. Didn't really pay much attention, but then did a double take and noticed a rotten hole about 2 inches long on the underbelly. For 3 weeks I beat myself up and the car for that stupid little hole. A MAP sensor wouldn't have had that problem.
I'm not going to lie here. It is a royal PITA. Some easier than others. Sensors you will have to buy. And then trying to figure out how to install them on an engine that was never equiped with them. It's all a matter of pateince and how much you really have. I've seen people do it in a weekend, and I've seen people spend an entire month installing one. Final test and tune prolly takes longer than the install. Some people follow other examples and use their configurations so exactly they're running before the end of the weekend.
As with anything of this nature it has a learning curve. If you don't know how an engine works mathmatically and physically then MS is not for you. But there are forums for this to help. I use a program called Engine Analyzer Pro(unrelated to MS) that I get most of my information from. It helps me fill in the blanks when I'm building picMicro's to inhibit or send false information to the ECU on my car. Engine physics isn't that complicated and most aspects can be auto generated by the software.
Research, read, more research, and read more. You can never know too much. Follow the forums and find communities that focus on the product and more over have a repository of downloadable config files. These will save you allot of headaches. If you see someone that's getting better times than you and he has the same setup (albeit rare with the cars you guys drive) look at the config files he's posted (if he posts them). You could find things as simple as timing settings or as complicated as a different fuel map. You may find something better just by viewing the other guys settings. Before long it doesn't look like greek anymore and you don't even persieve it as code.
I've seen the kit as cheap as 200$ and as much as 580$. Depending on if it was assembled or not. If your into assembling stuff the kit is for you, but without someway of testing it you might want to get the fully assemled unit. What looks good and complete visually may have a problem that could hinder installation on your vehicle if you don't know about the problem.
Questions cost nothing and without them life wouldn't be much fun.
PostPosted: Sun Oct 22, 2006 12:46 pm
thanks a lot man!.... I really apreciate.
I am still reading, hope to get to know a little more.
:D
Stock Sucks...!!
Mods List:
Iridium Sparks
ACCEL Coil
240cc inyectors
52mm TB
K&N filter
195/50 R15
Ate. brake Fluid
PostPosted: Sun Oct 22, 2006 3:34 pm
Thank you Trencher, great info! :wtg:
Back to reading... :lol:
2000. Hyundai Sonata EF 2.0 (Hyundai version of 4G63 and F5M22)
1991. Mitsubishi Lancer C62 1.5 (4G15, F5M21)
PostPosted: Tue Oct 24, 2006 12:47 am
That's great info Trencher.
I know alot of the Toyota guys like to use MS because they can't chip their stock ECUs. I know someone that uses them alot and the basic tuning is very simple. There is even an "auto-learn" feature that will make you save alot of time. You can do the fine tuning after this and you'll be ready to burn those tires.
PostPosted: Thu Nov 30, 2006 11:27 am
thanks
here u go...manual for 4g15
http://www.msextra.com/manuals/MS_Extra ... #sohcmitsy
go DRAX go..!!..tuning in ReaL TimE
PostPosted: Wed Dec 06, 2006 9:05 am
Great info! Thanks! :)
 Post subject: MAP or MAF
PostPosted: Thu Jun 21, 2007 3:54 am
Guys,
This is not a reply but a follow up question Can we still use MAF in conjunction with EGR or oxygen sensor for megasquirt i found out this ecu is superior when it comes to tweaking and i also learned that it has available analog input for this type of sensors
