It is currently Mon Oct 27, 2025 4:34 am
 Post subject: new Tach
PostPosted: Tue Feb 24, 2004 4:58 pm
hey guys today i finally got me a tached gauge cluster... it was from a automatic but it still serves its purpose and also looks good at the same time.... i hope to get some of them white face gauges that gage are producing to slap onto them.... :twisted: and also i have a question..... will injectors from a 4g64 galant motor run in my 4g15 colt??? i also have the k&n with a custom intake... and im about to put a 1.8 TB on it... and apply my gutted cat..... any help would be appreciated
www.4g61t.org, My Anti-Drug
Member #486
1992 plymoth colt 1.5 4spd soon to have 1.8 parts and much more
1991 Eagle Talon TSi AWD eibach springs, kyb shocks, front strut bar, white face gauges, and a system
PostPosted: Tue Feb 24, 2004 10:07 pm
If i'm not mistaken, the 4g64 injectors are the same used in the 4g37, 210cc. If you use them, i would also use the associated MAS. Using the 4g15 MAS will make it way rich. With the 210cc injectors and MAS it will run a bit lean at idle and may surge a little when cold. Other than that, they will run fine.
04' Olds Alero
91' Colt GL hatchback
4g15 12valve 5spd.
Lots of little s#@t
PostPosted: Tue Feb 24, 2004 10:28 pm
Voted off the island
are u sure the 4g64 injectors are the same i think that they are smaller then 210 i think 210cc only come out of the 4g37 engine and a 1.6L dohc NT engine.
i am alos going to put these in my colt but i ported out my intake and used a 60 mm tb and a cold air intake. i hope it all runs smooth.
-Jeff
'91 colt 200e 4g63 naturally aspirated
PostPosted: Tue Feb 24, 2004 10:30 pm
I still have not added my 4g37 ecu with injectors its been too damn cold I'll lt you know how all the package works on the car. I also gotta change a drivers CV joint its mad clicking.
PostPosted: Tue Feb 24, 2004 10:45 pm
I think the 4g64 has 240cc injectors although I can't verify that for certain
PostPosted: Tue Feb 24, 2004 11:33 pm
how do you tell their size?
Member #486
PostPosted: Wed Feb 25, 2004 7:17 am
It'll have a series of numbers stamped on the sides. Las 3 digits are the size.
04' Olds Alero
4g15 12valve 5spd.
Lots of little s#@t
