It is currently Sun Oct 19, 2025 7:53 pm
 Post subject: G32b motor parts
PostPosted: Fri Jun 24, 2016 8:35 pm
I will be removing the 1.6 sohc G32b motor really soon.
Parts will be available.
Note worthy parts are custom webcams cam re grind.
Stock lightened flywheel with centerforce stage 1 clutch.
Non cracked exhaust manifold.
I have a few 9b turbos. If anyone needs cores.
DRCOLT
1989 3g Colt GT turbo w/4g63t
 Post subject: Re: G32b motor parts
PostPosted: Fri Jul 08, 2016 10:38 am
Dr.colt! Some of these parts would be of some use to me. I just pulled out a g32b from an 85 colt. I grabbed the ECU and the wiring harness that goes through the fireall on the passenger side. I forgot about all the wiring to the fusebox and through the driver side fender. Do u still have these wires? I'm swapping into an 88 g15b.
PostPosted: Sun Jul 10, 2016 1:28 pm
All wiring to the fuse box in mine will stay. I'm just replacing motor wiring.
Why not do a 4g63 swap?
DRCOLT
PostPosted: Wed Jul 13, 2016 9:12 am
Maybe a 4g63 swap would be easier for finding parts. i know u have upgrade a lot of other components too to make it work and my intention is to just make an ice racer.
