It is currently Tue Oct 21, 2025 12:31 am
PostPosted: Thu May 28, 2015 2:41 pm
Car was hit HARD in the rear. I bought it and used it to put 1458/2000 back together as my driver. I have a bunch of stuff i know you csm junkies need. I wish i had this when i bought all the vr4 parts for my csm.
Bunches of interior things
front K frame assembly hub to hub (drivers side lca, shock, and tie rod are bent)
rear sub-frame hub to hub including calipers (rotors are grooved and junk)
Transfer case
Drive shaft
I will consider selling the stock wheels but the offer would have to be right
Ask for anything you might need and i can get pictures and prices for you.
PostPosted: Thu May 28, 2015 4:18 pm
I need where the foglights and dim switch i thing goes, mine has 1 tab broken
PostPosted: Fri May 29, 2015 2:07 pm
I don't have the fog lights and the Dems which I have also had a broken tab
PostPosted: Fri May 29, 2015 5:58 pm
Injectors?
PostPosted: Fri May 29, 2015 9:50 pm
Stock 450cc i have a set somewhere yeah.
PostPosted: Fri May 29, 2015 10:08 pm
How much?
PostPosted: Sat May 30, 2015 9:29 am
75 shipped?
PostPosted: Sun May 31, 2015 8:12 pm
No one wants brakes? Calipers? hubs? rear disk conversion? Nothing?
