It is currently Sat Apr 27, 2024 4:04 am
PostPosted: Thu May 14, 2015 12:19 am
1992 colt just finishing up the awd auto swap
Put the passenger side axle in and couldnt bolt the knuckle to the strutt
The bottom hole lines up but the top is about a quarter inch off (axle is completely compressed so you cant push/angle the knuckle closer to the car)
using expo knuckles/dsm hubs
Elantra controll arms
Dsm strutts with colt top hats
Its like the controll arm isnt long enough
The strutt bolt holes are in the wrong spots
other wise the only way to fix it would be to get camber plates and run negative camber...
PostPosted: Thu May 14, 2015 11:35 am
What axles?
PostPosted: Thu May 14, 2015 12:04 pm
sorry thought I said them
There dsm axles
1g auto awd
With the expo knuckles and elantra control arms i'm supposed to be able to use them
PostPosted: Thu May 14, 2015 3:19 pm
Sounds like you don't have the axles you think you have. But if the axle is all the way seated in the trans and you're positive it is a DSM axle, I'd suggest trying a turbo mirage axle.
Users browsing this forum: No registered users and 58 guests
