It is currently Sun Oct 19, 2025 11:41 pm
PostPosted: Mon Feb 23, 2015 8:27 pm
Sorry for taking a while to get this up but i do have a link to the pictures of the stuff i am selling. Cleveland Ohio
https://www.dropbox.com/sh/zqk0dhaevug5 ... YFIPa?dl=0
4 transmissions available, they are all fwd turbo transmissions. Check link for pics.
All 4 of the transmissions are going for $300, i will ship them if needed. I am converting to awd so i no longer need them.
92 - has phantom lock installed, works great except over 5500 rpm getting into 3rd is a little tough
90 - i bought it and was told that i works but have not installed
90 - parts trans, all parts there
90 - parts trans broken shift fork but most everything else is there
RC 1600 CC injectors, never have seen E85. They have one season on them and work perfectly $250 shipped
Rear Disc Conversion - $150, i have e brake adapter kit also, i will ship if needed but would prefer pickup
Centerforce pressure plate - i toasted the clutch and would need resurfacing $25
FWD fly wheel $25
Walbo 255 twin fuel pumps with -8 feed and -6 return $150
1G awd radiator $20
AWD shift cables and shifter assembly $100 in perfect shape from 1992 laser
I also have a bunch of random parts, throttle bodies, filler necks, bolts and brackets, CAS
PostPosted: Wed Feb 25, 2015 1:59 am
Are those the white top ford injectors? If so I will gladly take them. Can you do any better on that price?
1985 Mitsubishi Cordia
Build in progress
