It is currently Wed Oct 22, 2025 1:52 am
PostPosted: Fri Nov 29, 2013 2:17 pm
Right lads my rad fan is not coming on i wired it direct and it works also my heater fan not workingare they conected or two seperate. Problems or are they
ran from the same relay thanks in advane
PostPosted: Fri Nov 29, 2013 3:57 pm
heater fan is inside the car right behind the glovebox..so check the fuses for that..and make sure its plugged in.. ( you should be able to lay on ur back and look up under the dash behind the glove box and see it.. the plug will be facing downwards)
the radiator fan not coming on is the temp sending unit at the bottom of the rad..(I just replaced mine yesterday) it has a white plug on it and should be brass in color. fan comes on at 201 degrees and shuts off at 189.
