It is currently Sat Apr 27, 2024 5:29 am
PostPosted: Wed Nov 27, 2013 12:27 am
Starting a build thread for my latest project. I just bought this car a little over a week ago Mid nov 2013. This is my second original '89 plymouth colt turbo.
This car is in excellent overall condition with absolutely minimal rust (mostly surface underneath) No big dents just a few parking lot dings. The underside is showing a little rust on suspension pieces and some starting on a couple seams...I plan to get on this big time as it is still minimal and is fully recoverable.
I always wanted a white turbo, but I have say I have fallen in love with this silver car. The wheels with the polished lips, the stance and the exhaust look mean as hell to me. I was following the car when we were driving home and it just looks "right". The suspension is taut (not bouncy)and over bumps the car has a purposeful look to it, like a lot of well prepared autocross cars.
Anyway
I will be doing a conservative build on this car keeping some of the mods that were already done and stepping up on a few items. I would be very happy to have a mid to high 13 sec car when done.
current mods
Engine/performance:
-450 injectors
-13G turbo
-HKS high flow air filter
-EGR bypass
-Underhood bar and plate intercooler with sucker fan (little bigger and thicker than 1g smic)
-looks like a 2.5" turbo back with Flowmaster (maybe real)type muffler. I have to check the downpipe
-EGR blockoff
Suspension/chassis
-GAB rear adjustable struts
-KYB GR-2 fronts
-GAB strut tower bars front and back.
-Battery relocate
-15x7 inch OZ/MSW Pluton
-unknown aftermarket coils.
-whiteline rear sway (I have to check front )
Appearance/interior
-Autometer vac/boost, oil pressure and water temp gauges
-amp for old aftermarket stereo
-fake hood scoop
Almost all work was really nicely done and tasteful (not to insult the previous owner, who was extremely nice, but the more I look at the hood scoop the more I think that will be the first thing to go) I am happy that it has recently had the timing belt and alternator replaced.
It needs at least one axle as it is clicking pretty bad and the brakes are a little soft. I was told the parking brake is frozen and I might need to see if the rear calipers have perished.
planned upgrades
14b
2g manifold
upgraded o2 housing (still deciding which way to go)
190lph walbro
Dsm link
2g mas with hard pipe
might stick with the 450 injectors for now otherwise I have a set of FIC 650s
These are the previous owners pictures. I plan to take a lot more as I go.
Hope you like it as much as me...
Craig M.
PostPosted: Wed Nov 27, 2013 12:44 am
Where did you get the gab strut bars?
PostPosted: Wed Nov 27, 2013 1:36 am
Sorry, I didn't buy them. The owner just before me didn't install them either. They were on the car from a previous owner, likely done somewhere between the late 90's and 2002.
PostPosted: Wed Nov 27, 2013 9:20 am
I'm jelly, what a nice solid car you got there.
PostPosted: Wed Nov 27, 2013 6:54 pm
Was this one in WI? I've got an aftermarket 2.5" recirculated o2 housing you can have for $40 if you're interested.
PostPosted: Thu Nov 28, 2013 5:44 pm
Nice car, I like silver as well! good luck with build :)
PostPosted: Sat Nov 30, 2013 7:10 pm
Well the GAB strut tower bars are a direct swap over from the Galant VR-4's so that would be my guess as to how one of the previous owners obtained one. At least on the front. Not to sure about the back though. :D
1991 Plymouth Colt - Project
PostPosted: Mon Dec 09, 2013 7:30 am
Put the car on a lift to check out the overall condition and get a better idea of what I am dealing with.
Car is in even better condition than I thought. Very minimal rust a few areas. No big dents.
some things I found while on the lift
2.5 press bent turbo back.
need a passenger halfshaft
rear calipers are frozen
no front sway at all
some more pictures
Intercooler seems nice although not very big. It has cast Turbonetics/Spearco Intercooler Endtanks
core is ~10x12 and is 3" thick
wheel well lips look pretty good
this is one of the roughest looking pictures of the car.. you can see a little surface rust on a few spots out back
the rest looks great underneath
you can see the front chassis brace here
and the gab rear brace here
PostPosted: Mon Dec 09, 2013 7:12 pm
Just curious on how it was determined that the calipers are stuck. Were they twisted AND compressed at the same time? Sliders only? Park brake pivot operate the piston at all?
It's a troublesome rear brake setup, and pulling calipers means also disconnecting the rear parking brake. Flip up style calipers, for the purpose of removal, is a big pain.
I cannot however, believe how clean those rear fender lips are looking!!!! Someone said they were jelly seeing that car, I'm jelly when I see what my rear lips should look like. :rock:
Users browsing this forum: No registered users and 116 guests
