It is currently Fri Oct 24, 2025 9:56 am
PostPosted: Mon May 13, 2013 11:28 pm
Only thing on the whole car/motor that hasn't been replace. I'm gonna be getting a new Comcast to eliminate any possible culprits in my shifting problem. This is a 91 Plymouth colt, do you guys just replace with the stock cmc or upgrade? Order for any other model? I already have ss clutch line directly to slave. I'm just curious before I order. Make sure I get the right one.
PostPosted: Tue May 14, 2013 10:53 pm
Best bet is to score an OE Mitsu piece.
You can't really "upgrade" a clutch master cylinder. If too much fluid is pushed into the slave then the fingers on the pressure plate can be over-extended, if too little then the clutch doesn't disengage. Has to be just right...
PostPosted: Tue May 14, 2013 11:03 pm
Thanks, not so much as upgrade..but better quality from another car..I actually just went ahead bought one for a colt GT, just need change out
