It is currently Thu Oct 23, 2025 4:52 pm
 Post subject: 96 awd 5 speed FS/FT
PostPosted: Fri Nov 23, 2012 9:03 pm
I have a 1996 Eagle Talon TSI AWD 5 speed converted to look like an eclipse. It has 2gb Front bumper with 2ga rear. The front bumper has been modified for a bigger opening for the FMIC. It has a built 6 bolt in it. Ross 8.8:1 pistons, Eagle rods, arp hardware through out, MLS headgasket, BC 272 cams, BC SS valves retainers springs, revised lifters, Power Technology Timing belt, Balance shaft delete. Very solid motor with under 5,000 miles. SouthBend clutch kit rated at 600 Ft pounds of torque. Holset HX35 with a t3-dsm flange adapter,Oil feed line with adjustable pressure specifically set for the hx35, -10 AN return line, HKS Wastegate with 20 lb spring, 2 brand new slim fans,New thermostat, Brand new VRSF FMIC, Relocated fusebox and battery. Brand new DSMlink with speed density, All SD sensors are brand new which include GM IAT Gm MAP. Brand new AEM Uego Wideband. Brand new Glowshift 7 color tinted gauges Boost -30 +30, Water temperature with adapter for upper radiator hose, Oil pressure, Gauge cluster pod and modified center console. As some sort of short throw in it with evo 8 Shift knob, Welded center diff, NO PS NO AC NO HEATReal Greddy type S BOV PTE 880 CC injectors Walboro 255 inline lph pump, Fuel lab inline filter befor pump Aeromotive AFPR , Stainless steel lines in bay Will come with extra line, Stainless steel braided Clutch line, Extended slave rod Fuel pump rewire. Im sure im missing some stuff but now for the bad. The transmission has a grind when you shift into 2nd fast . I think its the synchros. The interior needs finished and some misc pieces are missing. It does run and drive though. I tuned the idle in and was working on the cruise tune. It needs WOT tuned. I blocked off the ISC and FIAV so when you first start it you have to feather the throttle a little bit. The wheels and tires have seen better days and would need replaced soon. The interior is id say like a 6 out of 10 and exterior would be 7 out of 10. It does need an exhaust, tune, catch can set up plus some misc things im sure and your off to the races. Text or email me with any comments questions or concerns. I have hurt my back at work so i can no longer deal with this car. Come make me an offer and we will try to work a deal. Im sure im missing some stuff though. IM asking 7000 ObO. I have way more than that invested so please be reasonable. NO LOW BALLERS. Will consider trades of eqaul value or some lesser with cash on top. You will get some spare parts as well. text email 8127674395 Thank you Would love to trade for a colt
