I have the oem turbo from my 95 evo 3. I had it on my spyder for the last month made 398.8 on it w/e85. just took it off for a bigger set up since the engine is all broken in now. It has no in and out play at all and no side to side.
The turbo is set up for extrunal gate off the 02 housing. It is also clocked so the cold side is facing down.
will come with. front and back coolant lines,banjo bolts,and copper washers. oil feed adaptor,banjo bolt,and copper washers,10an drain line fitting (2 weeks old) for turbo,10an bolt on fitting for the oil pan,s.s. modded j-pipe for down facing to drivers side.
take 375.00 for it all
or willing to trade for a 2g smim or other parts for my 2g or evo 3
could add a tial 38mm gate and oem drain line in some trades
