I have a 1994 eagle summit 2 door coupe that currently has had a 4g63t motor swapped into it and is set up for drag racing. The car HAS a clean title and can be registered if you so desire. The car has:
- 4G63t Motor swap from a Mitsubishi eclipse GSX (fresh rebuild) 2g pistons, 1g rods, water pump, timing belt, hoses, all gaskets
-Full 8 point roll cage
- craiger rims
- Hoosier slicks
- SS304 custom manifold (not Chinese) Tig Welded by myself
- Automatic Trans
- evo 3 16g turbo
- 2g mass air
- Evo 9 injectors
- Evo 8 seats (with 5 point harness on driver side)
- 1G DSM suspension up front.
- 1G Talon 2 piston calipers and rotors (master cylinder)
- Solid Motor mounts
- aluminum radiator
-And much more I cant think of now
I can email or text videos of the engine running/revving
I am Asking $3,200 parts alone are worth it. First person with cash takes it I need it gone[/B]
Reason I am selling is because I am starting a new project (drift car
This car is not Turn Key Track ready at the moment. It needs a Trans ECU or Shift box (currently in Limp Mode). It does drive in reverse and forward but the car is stuck in limp mode due to no TCU (3rd gear)
If you are interested please shoot me a text or call at:
847-274-7744
Jordan
http://www.flickr.com/photos/64021387@N04/
