It is currently Sun Nov 02, 2025 6:31 am
PostPosted: Sun Sep 30, 2012 2:44 am
Well, i have received my Jay Racing kit but the lower bracket look more thick on one side.
The Colt half shaft need to be fixed on the bloc with the OEM AC bracket (cutted) or 8mm spacer: http://www.4g61t.org/forum/viewtopic.php?f=6&t=35529
I have found more explication on the Evo 123 forum : http://www.evo123.net/showthread.php?t=8537
Look the post #20 .
I have cloned the Jay kit with steel metal for best strong and i have now a perfect thickness
Plasma cutting
Made a template for soldering
New bracket vs hold ( we have also stepped the rear side like the Jay bracket )
Let me know what you think ?
Remy
PostPosted: Sun Sep 30, 2012 6:18 pm
Looks good! :supz: would you consider making another and selling it?
PostPosted: Sun Sep 30, 2012 8:43 pm
Looks nice, now you can sell copies haha.. Plasma cutting is fun!! I have one the jay racing tool for doing timing belts.
PostPosted: Tue Oct 02, 2012 2:35 pm
i made mine out of 5/16 plate, a large bolt (drilled through) and thin washers on the back for the "step" about 3 years ago
worked great.
then i found a better way that does not need that tensioning rod.
copy the buschur racing kit, and tension the alternator off the block. keeps it straight and is much sturdier, and i have not thrown a belt yet.
PostPosted: Wed Oct 31, 2012 3:07 pm
Yes if you use the tensioner rod from he Jay Kit you need also to relocate the PTU, the rod hit the PTU bracket ...
I have made a tensioner with a aluminum bar plate, finnaly i use only the belt from the Jay kit and not i dont sell a lower bracket copy sorry .
