It is currently Sat Apr 27, 2024 12:33 am
 Post subject: heater core blues.....
PostPosted: Sat Sep 29, 2012 1:34 pm
Today I set out to replace the heater core on the buggy. The dash was "interesting" to remove and the heater box easy to take out as you can see....
While changing the core I pushed a little too hard on the pipes and CRACK!!! Broke the weld.
Ok, off I go to the rad shop. They wont fix it, don't have the material to weld it properly. Excuse me!? I went to college for refrigeration so soldering brass isn't a big problem. They're just too F'ing lazy. So I get my propane torch kit with solder and flux and off I go to the back yard to weld my brains out. What do you think?
Hopefully if all goes well it will be back in action for Monday. Fingers crossed.... 8)
PostPosted: Sun Sep 30, 2012 9:51 am
Nice repair.
I did the same to my 3G CSM. I pulled one side of my core off when I was removing an old heater hose. (I should have just cut it). My dad is a plumber and I know soldering this stuff isn't too bad.
PostPosted: Tue Oct 02, 2012 12:38 pm
Well, I have most of the dash back together and HEAT GLORIOUS HEAT! Had to let it run off and on for about a day to make sure there was no leaks. Its dry and I am happy with the outcome. Hard to believe full blown rad shops wouldn't touch it to fix a simple soldered joint. I won't be shopping there anytime soon that's for sure! Pics to follow... as soon as the rain ends :supz:
