It is currently Wed Oct 22, 2025 6:44 pm
PostPosted: Mon May 14, 2012 9:08 pm
Prices include shipping. Parts will be shipped within 24 hours unless otherwise notified. I prefer Paypal (add 4% to price) but will take a check/money order and will ship once money clears. Any questions, PM me or text (334) 657-O815.
Performance Parts
Used Wiseco 6559M85 Pistons - STD sized - Came out of an incorrectly built motor I inherited from someone else. Have idle time on them only. I had them checked out by my machine shop and they are in great shape. $225
NEW in Package Wiseco Piston Rings - STD size for the pistons listed above $85 FIRM
1G MAF Translator version 2.02 - Was being used in conjunction with DSMlink but upgraded to ECMlink V3 and a GM MAF Cable, so I no longer need this. The plugs are mint, no damage whatsoever. The unit works flawlessly and comes complete with all the screws and plastic cover for the box. $85
1G 6-Bolt Cylinder Heads - Too many to list all. I have a couple used that are good for cores. I have one that is in running condition (Just removed from my 1G when I swapped it for a built head) and a few that are good cores, but need caps. Offer
2G Style MAF - Mint Condition. "055" on the label. $25
FIAV - Blocked off to eliminate the Fast Idle Air Valve with JB Weld. Good shape. $20
GT3076R T3 .63 A/R Turbine Housing - Looks new. I never used it. Excellent shape. $100
SBR Exhaust Manifold - HUGE manifold - bigger than EVO III. Has some hairline cracks that are irrelevant, but worth mentioning - $55
BEP Exhaust Manifold - Like new, barely used - SOLD
Starion FMIC $50
180* Aluminum U-bend pipe to weld to a Starion FMIC for piping. Or whatever else you need. Purchased from RRE. $25
I have 9 years of DSM stuff laying around. If you need something, check out my pics. If you don't see it, PM me - I probably have it. Make offers on this stuff Some parts worth mentioning:
- NT and Turbo Throttle Bodies
- Water Pipes, both NT, 90 Turbo and 91+ Turbo
- Coolant Reservoirs
- Clutch Master Cylinders
- Brake Master Cylinders
- 3-Bolt Rear End (MT) w/axles
- Misc 6-bolt Motor Parts (Sprockets, pulleys, mounts, etc)
- 6-bolt Motor Mounts
- Shifter Assemblies
- Stock O2 housing in MINT shape
- Misc. Electronics - Several CAS, TPS, Coils, Etc.
- Speedometer Clusters 1G Turbo
- Misc. shields and tin pieces for the motor
- 90-91 Mitsubishi center lens (goes in between the headlights)
- 1G Steering Wheels
- 1G Intake Manifolds
- 1G A/C Compressor
- 1G Axles (AWD)
- PS Brackets
- Stock Turbo O2 heat shield
- Misc. Engine Mounts
- Purple Cam Gears - Sexy Sexy.
MUCH MORE - Shoot me a Text or PM
Photobucket Link: http://s132.photobucket.com/albums/q23/ ... 1QQtppZZ16
PostPosted: Mon May 28, 2012 2:50 pm
Do you still have the 2g maf? Ill buy that ...
How much you want for the steering wheel? Is that a 1g steering wheel, leather one? Are those axels for the colt turbo, or they dsm axels?
PostPosted: Mon May 28, 2012 9:43 pm
I need a Non turbo waterpipe,Let me know if you have them i need 2 of them
PostPosted: Thu May 31, 2012 6:29 am
DSM Axles. 1G leather steering wheels. PM if interested.
PostPosted: Thu May 31, 2012 6:32 am
I think I have them. I'm out of town visiting family, but I'll be back on Sunday. I'll check for you then.
PostPosted: Thu May 31, 2012 8:05 am
Please do that my friend
