It is currently Wed Oct 22, 2025 3:16 am
 Post subject: COP, A1000, CAS, etc...
PostPosted: Sat Nov 26, 2011 5:51 pm
This is all OBO, feel free to low-ball. I want it gone. As much crap as I can stuff in to a flat-rate box the cheaper things get, quickly...
It looks like I can fit all these in one box so it would be $50 shipped to 48 states:
  • 91 awd crank pulley
    89 turbo center caps
    89 turbo shifter assembly
    wheel spacer
    89 turbo e-brake
    throw-out bearing
    89 turbo clutch master
    4g63 driver side engine mount
TRE 4-Spider Center. I would clean it well before using since it's seen some 4th gear material ;) $200 shipped, lower 48.
1g AWD Trans Hard Parts (back when I thought it was worth the time to rebuild the sticks on these DSM thingys...)
RCi 5-point harness, brand new 2". The DOM is 05/09 but I've never had tech bother me about the dates in the past. $30 shipped, 48 states.
Engine mount, good shape. $20 shipped to 48 states.
Clutch slaves - worked and didn't leak when I removed them, $20 shipped (all) 48 states
*New* throwout bearing. 6 bolt awd. $10 shipped or free if you buy something else. 48 states.
Clutch master, worked and didn't leak when removed for the auto. $20 shipped, 48 states.
'89 turbo shifter, I shimmed it so it's not as sloppy. $20 shipped, 48 states.
'89 Turbo E-brake free if I can fit it into a flat rate box with something else you buy... 48 states
'89 Turbo shift plastics, price based on shipping
One 5x114.3 wheel spacer (5mm). Free if you buy anything else.
'89 Turbo center caps, need to be cleaned up and painted. $20 shipped, 48 states.
Crank pulley (91awd), $20 shipped, 48 states
'18 X5
'19 M5 Comp
'17 Fiesta ST
PostPosted: Sat Nov 26, 2011 7:29 pm
Kinda want that pump. Lol
PostPosted: Sat Nov 26, 2011 10:44 pm
Dan, Steve at www.throttlebodys.com will pay you $45 for the 91+ turbo throttle body, just fyi. I sent him 7 or 8 a few weeks ago.
PostPosted: Sat Nov 26, 2011 11:03 pm
Seasoned Member
I PM'ed earlier, but I'll take the CAS, TB, and pump.
PostPosted: Sat Nov 26, 2011 11:14 pm
i pm'ed earlier also.. for the blanket and hoop..
PostPosted: Sun Nov 27, 2011 3:14 pm
CAS, TB and A1k sold.
'18 X5
'19 M5 Comp
'17 Fiesta ST
PostPosted: Sun Nov 27, 2011 5:49 pm
PM'ed about the COP and some other stuff.
PostPosted: Sun Nov 27, 2011 5:55 pm
Never received a PM from you.
'18 X5
'19 M5 Comp
'17 Fiesta ST
PostPosted: Sun Nov 27, 2011 9:10 pm
OK tried again hopefully that one went. Let me know. Thanks, Nick
PostPosted: Thu Dec 01, 2011 12:41 am
Loop and trans shield are sold.
Crane, COP, both shifter cables, misc shifter linkage mounts are also sold.
Thanks gentlemen.
'18 X5
'19 M5 Comp
'17 Fiesta ST
PostPosted: Thu Dec 01, 2011 12:45 am
Figure how I can fit it into a flat-rate box and let's make a serious deal.
'18 X5
'19 M5 Comp
'17 Fiesta ST
PostPosted: Thu Dec 08, 2011 9:18 pm
Added a 5-point and group/box deal...
'18 X5
'19 M5 Comp
'17 Fiesta ST
PostPosted: Thu Dec 08, 2011 9:30 pm
Dibs on the harness if it is a 3". I'll even kick a bit more since I am on the other side of the US....
PostPosted: Thu Dec 08, 2011 9:40 pm
It's a 2"
'18 X5
'19 M5 Comp
'17 Fiesta ST
PostPosted: Thu Dec 08, 2011 11:42 pm
Pass!! Sorry bro...
