It is currently Wed Oct 22, 2025 7:17 am
PostPosted: Tue Aug 09, 2011 9:53 pm
After 4 months of trial and error I finally got my colt back up and on the road.
It started with a track day and my horrible driving. I blew the diff into pieces throwing pieces of it through the bell housing and case of the trans. I ended up buying a shep trans off of another member here on the board and thats where the problems started. I had a km210 in the car originally and the trans i bought was a f5m33 which i didnt think much of. Got the new welded diff in and bolted the new trans in not thinking. Had problems with the axles first off, trial and error led me to an equal length set up and gt axles (after reading the axle thread). Then flywheel and clutch problems. When i got it all tucked away and together i noticed the axles didnt fit too well into the diff, just rattling around and after a little reading i found i had the big diameter diff which i had to replace with the correct one. Tonight I finally got the car out on the road and when i got up to cruising speed i had a TERRIBLE rattle so i pulled over and checked my trans all my mounts, all the axles and ball joints and everything i could think of. Got to my buddies house and noticed i was missing a lug nut checked all the others and turns out i got a little anxious and forgot to tighten my lug nuts all down.
I have to say for 5lbs it feels a hell of a lot better than it did before (new tune) and a big thanks to all of you for all the knowledge here on the board, it helped me out in more than one place throughout my rebuild. Thanks all and thanks for reading my long boring story
PostPosted: Wed Aug 10, 2011 3:36 am
Glad its back on the road! Will you be taking it to shootout?
PostPosted: Wed Aug 10, 2011 3:44 am
Congrats, it all seems worth it when you can finally take it out and beat on it for the first time!
PostPosted: Thu Aug 11, 2011 8:41 am
If everything goes right then yes I will be there
And as far as beating it goes I gotta resist it to break the clutch in right
PostPosted: Thu Aug 11, 2011 1:26 pm
whats the right way to break in a clutch?
all you need to do is drive it in stop and go traffic for 10 or so miles, Just get get that first bit of stuff off.. Then its good to go. Ive done that to every clutch ive ever replaced
PostPosted: Thu Aug 11, 2011 6:05 pm
Thats what i like to do only for about 50 miles just to make sure, and i just finished that 50ish miles and will get to have some fun tonight
PostPosted: Fri Aug 12, 2011 7:01 am
How does the trans feel? It shifted pretty decent in my car
_____________________
1993 single turbo supra
2000 Lexus sc300
2016 ram 1500
PostPosted: Fri Aug 12, 2011 5:56 pm
The trans feels great. finally got some good pulls in and have a small boost leak somewhere but it does great
