It is currently Wed Oct 29, 2025 7:23 am
 Post subject: Clutch issue
PostPosted: Thu Jun 09, 2011 4:35 pm
My car has a full ss Dsm clutch line (master to slave), new master and slave cylinder and new act 2100 clutch that I got from 89mirageman. I bled the shot out of it but the pedal still feels weird. It goes down about halfway then engages really hard. It almost feels like your pressing a button. The trans will also not go in any gear until you start to release the clutch. Any Ideas on what it could be?
_____________________
1993 single turbo supra
2000 Lexus sc300
2016 ram 1500
 Post subject: Re: Clutch issue
PostPosted: Thu Jun 09, 2011 5:45 pm
Sounds like you need to adjust the height of the pedal, either that or you didn't bleed it correctly. When I swapped out the master and slave cylinder on my 97 LS sedan I wasn't bleeding it right and still had issues. Then I found the how to on TRE's site and it worked perfect. I posted a link to it in one of Incoltnito's threads about a week ago.
PostPosted: Thu Jun 09, 2011 6:10 pm
Cool I'll check it out
2000 Lexus sc300
2016 ram 1500
PostPosted: Thu Jun 09, 2011 8:04 pm
Yup...might have to adjust that rod on the master. Just replaced my master and did the same thing. It's easier to do with an extra person around, same goes for proper bleeding technique.
Good stuff - trucks bring it!
PostPosted: Thu Jun 09, 2011 8:07 pm
Oooops....here's the thread
http://www.4g61t.org/forum/viewtopic.php?f=22&t=34832
