It is currently Sun Oct 26, 2025 3:50 am
PostPosted: Tue May 03, 2011 12:02 pm
As tittle says im looking for some CSM GT side skirts and turbo hatch wing!! Let me know what you have!!
PostPosted: Tue May 03, 2011 2:30 pm
I've got a wing, with the two mounting bolts, but no other hardware, asking $50 shipped... or make me an offer.
49 International KB-2
72 Dodge Colt
73 Dodge Colt (Project)
84 GMC K3500
85 Dodge D50 Diesel Swap
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Wed May 04, 2011 11:32 am
does it take any other mounting hardware?
PostPosted: Wed May 04, 2011 1:12 pm
They have I think 4 tabs that screw I into the hatch that the wing clips into, then the bolts hold it in place. I don't have any of them, they were not with the wing when I got it. Maybe someone else can chime in that has installed one on a non c53a...
72 Dodge Colt
84 GMC K3500
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Wed May 04, 2011 3:34 pm
the 2 bolts should hold it down ok though right?
PostPosted: Wed May 04, 2011 7:45 pm
I'd think if you 3M taped it down and use the 2 bolts it would be ok, but maybe someone else will chime in that has installed one. I never have so I hate to tell you it would or wouldn't!
72 Dodge Colt
84 GMC K3500
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Fri Jun 17, 2011 12:23 am
The two bolts hold it down just fine, use blue loctite though. It definitely helps if you use a little weatherstripping, the factory used a foam around the edge to keep it from rattling.
PostPosted: Sat Jul 23, 2011 1:46 am
I have a turbo spoiler and side skirts in red. Should have most hardware still as the parts are still on the car. Make me and offer.
