It is currently Mon Oct 27, 2025 6:01 pm
 Post subject: riddle me this
PostPosted: Mon Apr 25, 2011 4:43 pm
for all you 4gxx ladies and gentleman out there....how the f*** do you take the crank pulley off with the motor in the car? i have the new style crank bolt that requires a socket, not just a half inch breaker bar.
_____________________
1993 single turbo supra
2000 Lexus sc300
2016 ram 1500
 Post subject: Re: riddle me this
PostPosted: Mon Apr 25, 2011 6:00 pm
first you unbolt and remove the complete tranny mount so its out of the way...
second you remove the DS motor mount.. make sure u have a jack under the engine with a block of wood (so not to damage oil pan).
once engine mount is out.. lower the motor till u can get to the bolt.
PostPosted: Wed Apr 27, 2011 1:53 am
on a colt, i dont screw with the front/back mounts at all.. just undo the timing belt side mount and then the 4 17mm long bolts that secure the lower crossmember to the unibody... put a jack under the crossmember or a block of wood under the oil pan and use a lack to lower it down enough for you to get the crank pully to clear the frame rail.
-1989 Colt GT (stock for now)
-1993 Dodge colt 4g63 swap
PostPosted: Wed Apr 27, 2011 6:16 pm
Ya, definitely need to lower the motor to get it off with a 4g6X car.
PostPosted: Wed Apr 27, 2011 11:16 pm
yeah luckily in dsm's you dont need to.. and my 4th gen colt it also comes off no problem.....
damn 3rd gens ahahah
PostPosted: Thu Apr 28, 2011 5:35 am
While the motor is down to do the pulley removal, reorient the bolt holding the alternator so it comes out the opposite to the factory. Trust me when I say that the next time you have to change an alternator, you won't be dropping the motor down to do so.
PostPosted: Thu Apr 28, 2011 6:22 am
Haha. Your about 2 weeks late on that one. I had to sawzaw the factory bolt off and go to the hardware store and find one close enough to match. Believe me I was pissed!!! Lol
2000 Lexus sc300
2016 ram 1500
