It is currently Sun Oct 26, 2025 11:28 pm
PostPosted: Sun Feb 13, 2011 11:20 am
Negative Nancy
Preferably it would be near Maryland for pick up. Just trying to help a friend out.
Thanks
Rich
PostPosted: Sun Feb 13, 2011 11:39 am
I have one that I would let go for $45 + shipping.
PostPosted: Sun Feb 13, 2011 2:12 pm
Negative Nancy
A few questions, Do all the turbo columns have intermittent wipers? Are they a plug and play as in will work with base model 91 summit? I guess I can just swap his ignition switch also. Can you post a few pics so I can see the condition of the wheel and stalk/levers. Shipping quote to Clear Spring 21722 please.
You think pulling the wheel would make for a smaller/cheaper shipping package or isnt worth the hassle.
Pm'd my email addy to you also.
Thanks again
Rich
PostPosted: Sun Feb 13, 2011 3:57 pm
I will grab some pics shortly. Actually one of the stalks is broken, it was like that when I got it. But his can be swapped over easily if they are in good shape. The wheel is already off and separate from the column. I have no idea if this one has the intermittent switch but I will check when I grab some pics. I will also wait on the shipping quote and make sure he is interested in it first.
PostPosted: Sun Feb 20, 2011 8:47 am
I also have a turbo column,except the steering wheel.
91 Talon (Full Drag Car)
PostPosted: Sun Feb 20, 2011 10:29 am
Negative Nancy
Looks like I have one coming my way already, but will keep it in mind if I decide to put one in my car too. Doing this for a friend and will see how hard it is.
PostPosted: Sun Feb 20, 2011 12:09 pm
I put a tilt/telescoping column/wheel in my sedan. You can swap the wiper/indicator controls between cars too. But you may need to look at the wiring, depending on the year of the parts/cars.
Since I did my swap my washer doesn't work; I'll have to trouble shoot that one. My car is very is a hybrid of wiring, 91 manual summit with 90 auto/AC dash wiring, 91 DSM engine harness. I've spent time tracing wires at the interior fuse block fixing things like break and signal lights. :rolleyes:
You may not need to worry about any of this though just be aware of it.
