It is currently Sat Apr 27, 2024 7:33 am
Post new topic  Reply to topic  [ 272 posts ]  Go to page 1 2 3 4 519 Next
 Post subject: whe3ls's hyundai
PostPosted: Sat Sep 18, 2010 4:33 am
here is my 93 elantra gls, im going to be doing a 5 lug swap along with 4wheel disc brakes, i want to awd swap but i need to figure that one out still. if i do it, it most likely with a solid axle form a d50, i also want to stiffen up the chassis, by re doing the stock frame rails 2 inch x 1inch square tubing and some other things
my nice little 1.8
i had to put head studs in cuz the stock head bolt had been reused did want to take anychances
and my parts car,90 awd, im trading the diff t case and trans for a 91 6botl turbo bottom end
 Post subject: Re: whe3ls's hyundai
PostPosted: Sun Sep 19, 2010 10:08 am
This got me more pumped to work on mine.
PostPosted: Mon Sep 20, 2010 12:11 am
thats good. if the weather is nice this coming firday im going to see how slow my car it.
PostPosted: Mon Sep 20, 2010 5:09 pm
This is going to be a great car. I am finishing the bugs on my Excel. Gonna drop in the Walbro today, so I can boost without fear of running lean from the Hyundai Fuel Pump.
92 Eclipse GSX (Dead)
89 Colt GT (AWD Swap) H1C
88 Cummins Suburban
69 Cutlass convertible
PostPosted: Tue Sep 21, 2010 12:46 am
You know it and I know it too....winter is coming, and we're pretty much screwed. I just put off buying that 89 colt in the valley with the 4g61 in it, solely cause the season is changing too rapidly for me to do a swap outside.
Good stuff - trucks bring it!
PostPosted: Tue Sep 21, 2010 8:13 am
i know winters coming, but i have a nice shop to work in. i have another project i have to finish.
PostPosted: Wed Sep 22, 2010 7:48 pm
A nice shop is just the key! Liking the Rx...keep me posted.
PostPosted: Wed Sep 22, 2010 11:17 pm
i sent you a pm
PostPosted: Sun Sep 26, 2010 9:03 pm
well i made my car sound like a honda, but now i can chirp my tires going into overdrive and when launching, my muffler had several holes in it, and made the the car sound bad
PostPosted: Thu Oct 07, 2010 8:29 am
i cut up my 90 turbo harness so i could get the injector wiring and resistor pack, i also cut out the turbo maf plug and cas plug.
full 90 engine harness what i started with
my mess
what i needed
whats left
also here is want ive been thinking for the rear axle, the setup will be close to whats in the awd colts. not mine, its a pic of the C83A Cyborg rear axle
PostPosted: Thu Oct 07, 2010 10:30 pm
My 91 Excel doesnt have Struts like that, Does an Elantra come with rear struts? Check my build page for a pic of what my rear trailing arms look like. Hopefully you were blessed with a strut setup!
88 Cummins Suburban
PostPosted: Fri Oct 08, 2010 8:50 am
the rear is like the 1g dsm's so yes i have struts
PostPosted: Tue Oct 12, 2010 5:43 am
i started working on my gls today. i pulled the ac out and started to do a emissions and vac delete. i also think my car has 1.6 head.
PostPosted: Fri Oct 15, 2010 10:49 pm
well i think my 4g67 my have given up. :( it doesnt want to start
PostPosted: Sat Oct 16, 2010 8:48 am
Well let's see buddy...you ripped out the EGR valve AND the stock intake system as well as added wires to the harness :lol: . Did you install those plugs and resistor pack from the turbo harness? Check your connections if you did and see why it won't start (ie no spark, no fuel, and so on). BTW that first line was a joke... 8) Let's try to walk through this and see what the problem is.
Users browsing this forum: No registered users and 163 guests
