It is currently Mon Oct 20, 2025 4:40 am
 Post subject: Parting out 2g tsi awd
PostPosted: Tue Jun 08, 2010 11:24 am
Parting out a 2g tsi awd. Here's a list of the parts available for sale:
All stock parts have 10x,000 miles (I believe it was 105 or 108)
rebuilt 6 bolt motor with 10,000 miles, arp headstuds and cometic HG, good compression before the car was disassembled (no smoking or leaks and all new timing belt and related parts when motor was purchased)- 800 for the longblock
> act 2600 clutch and street disk with 1000 miles- 175
> fidanza flywheel with 1000 miles- 100
> 14b turbo in good condition- 100
> 2g awd manual tranny, shifts good- 450
> 2g driveshaft- 40
> 2g rear- 350
> 2g t-case- 75
--Will do a package deal for the entire drivetrane for your fwd swap (t-case, d-shaft, rear and subframe and trans for 800 FIRM--
> 3000gt sl front brakes with calipers, brackets- 80
> 2g eprom ecu- 180
> 2g turbo ecu- 100
> 1g turbo ecu- 100
> 660 injectors (plastic insulator broke on one of two of them, but they work and seal just fine)- 125
> wire harness modified for 6 bolt swap- 75
> 2g maf with ebay intake pipe- 50
> eibach sways- don't know what they go for used, make offer
> walboro 255- 40
> 2g awd fuel pump assembly- 40
> safc- 100
> very faded and hazy vis carbon fiber hood (make offer)
> 2g prothane motor mounts except front mount inserts- 40
> full turbo back 3'' exhaust ebay downpipe, high flow cat, thermal research cat back- 250
> 2g gray power seats- make offer
> aftermarket steering wheel not sure of brand at the moment- 35
> evo III exhaust manifold- 45
> halman manual boost controller- 30
> mushimoto 2g aluminum radiator with 1 electric fan- 100
> 1g uncrushed bov- 30
> taylor 8mm plug wires- 25
>front mount intercooler kit, ebay core and homemade pipes--flanged for 1g bov- 150
> obx t3/t4 exhaust manifiold flanged for external gate- 100
> 90 wired cas- 30
> stock 2g o2 housing- 25
> ebay o2 housing with dump pipe- 50
> 2g datalogger cable and palm- 100
> ebay wheels and tires (tires are practically new)- 200 picked up
> 2gb white front bumper, has some cracks- 35 picked up
> fenders, white- 30 each
> shifter assembly with shift kit- 40
> greddy weighted shift knob- 30
> alternator- 35
> brand new starter- 45
> valve cover uncracked- 30
> sunroof- 45
> talon taillights- 35
> turbo gauge cluster- 35
> airbags- 35
Prices are without shipping.
PostPosted: Sat Jun 12, 2010 11:08 am
turbo, clutch/ flywheel, shift knob and afc sold
