It is currently Sun Oct 19, 2025 8:25 pm
 Post subject: 1g/2g parts FS
PostPosted: Tue May 18, 2010 11:44 am
I have a list of 1g/2g parts for sale. These prices are cheap to move this stuff out, so prices are firm. Prices do not include shipping either. Buy these up before the driving season comes back around or you'll be paying 2x these amounts for these replacement parts!!!
1g parts-
22 spline transfer case-50
gauge cluster with reverse indiglo lights installed-20
short throw shifter-20
3 bolt rear axles-40 for the set --You will NOT find these for this cheap once the season begins, and I know I'm going to receive 100 pm's about them in a month when everyone starts hitting the tracks...will sell the LSD pumpkin with the axles for an extra 20
blue performance radiator hoses upper and lower-15
alternator-30
awd starter-25
6 bolt oil pan-20
huge assortment of gaskets and seals--there is a head gasket amongst tb, turbo, o2, oil return, etc, intake and exhaust gaskets and seals, two oil filters--over 90 in gaskets and seals easily-40
new timing belt, not oem-15
1g coil pack-20
3 gauge pillar pod-20
pioneer cd player with brackets-30
autolite cf a/f gauge-25
aftermarket cast manifold (looks like OEM, but has thicker bungs for egt probes) also has an s stamped into it if anyone knows what brand this is-35
2g parts-
tyc 2gb black housing headlights (tab on bottoms is broke, but shouldn't be an issue)-70
2g mas w/ blue coupler to intake pipe-35
2g brake calipers, single piston-20 each
2g coilpack-20
2g intake mani-15 each
ISC-20
2g crank sensors-15 each
black airbags-30 for set
fwd starters-20 each
