It is currently Mon Oct 20, 2025 6:04 am
Post new topic  Reply to topic  [ 43 posts ]  Go to page 1 2 3 Next
PostPosted: Fri May 07, 2010 10:33 am
This is red sleepers old car and csmshaun owned it also....I daily drive it right now it runs great..I don't need to sell it just putting it out there....
Mods.
Original '89 Plymouth Colt GT (turbo)
Stock NA 4g63 bottom end
-balance shaft delete
-GReddy timing belt
4g63 turbo head and cams
-dsm link v3 lite
1g exhaust mani
GReddy 18g mated to 1g O2 housing
Hall-effect black top CAS
full 3" exhaust w/ 36" glass pack muffler
-side exit in front drivers rear tire
manual boost controller mounted on firewall
aem wideband
Fidanza 8lb alum flywheel
ACT 2900 unsprung 6 puck clutch
OE alum 1g radiator with 12" push-type fan
GReddy FMIC core with custom back-door end tanks
-plumbed with 3" aluminum pipe cold side
-steel hotside that steps up to 3" off the turbo
Custom wiring harness with small tuck performed and fuse box moved next to alternator
Hallman pro boost controller
3" GM maf in blow-through configuration
8 gal fuel cell in hatch
-6AN braided line to and from OE fuel rail that has been modified to accept -8AN to -6AN converters
Aeromotive A1000 fuel pressure regulator
Dual in-line walbro 255lph fuel pumps running off of proper rewire
750cc PTE Rochester injectors
Optima battery behind passenger seat
6 point cage welded to NHRA specs
Grant steering wheel (I'll give yah the stock one)
Autometer water temp, oil pressure, boost and fuel level
Rest of interior is there and clean, speakers are intact but the head unit in the car is junk...
GVR4 brakes with Hawk street pads in front
High temp Valvoline fluid flushed through
Stainless brake lines all around
KYB GR2 struts up front KYB AGX out back
Ground Control springs and coil perches
eBay brand strut bars (only kind available lol)
Adjustable camber in rear via Ingalls upper control arms ($$$$ lol)
AWD swapped with 4 bolt LSD rear
Trans shifts good and the trans, rear diff and t-case have Lucas oils in them. Trans has a welded center diff.Makes noise but shifts good..
Custom 2 section driveshaft
The car has an oil leak like every other mitsu...
Very old pic has 2g wheels on it now but looks very simular...
Str8fuct......
PostPosted: Fri May 07, 2010 10:47 am
$10 and 3 tacos?
PostPosted: Fri May 07, 2010 11:09 am
NICE!! any dyno numbers or quarter mile times? ball park price?
My feedback thread:
PostPosted: Fri May 07, 2010 11:21 am
No dyno numbers, just went 12.5 at 108mph a mile above sea level on a mild tune has alot left in it...
Price somewere around $6,200
Str8fuct......
PostPosted: Fri May 07, 2010 11:22 am
$10 and 3 tacos?
Make them pink tacos...LOL
Str8fuct......
PostPosted: Fri May 07, 2010 12:24 pm
Seasoned Member
You're in Castle Cock. heh heh.
PostPosted: Fri May 07, 2010 1:23 pm
Unless you changed that tank.. It was a 12 or 15gallon tank i believe..
GLWS
PostPosted: Mon May 10, 2010 12:09 am
Any more pics somewhere?
PostPosted: Mon May 10, 2010 12:35 am
These are the pics I took of it 2 years ago at the DSM shootout. The car doesn't have those wheels on it anymore.
http://home.tiora.net/tony/index.php?path=Red%20Sleeper
PostPosted: Tue May 11, 2010 12:19 am
Thanks Tonus! How about undercarriage, engine, or interior pictures? Is there a build thread on this car?
PostPosted: Tue May 11, 2010 7:10 am
thanks tonus...Search red sleeper and you will see the build threads....
Str8fuct......
PostPosted: Tue May 11, 2010 2:37 pm
If I wasnt buying bowdown's car I would pick this up.... This makes me want to get rid of my colt though and pick this up I really really want an awd :wall:
If it has Tits or a Turbo your gonna have problems...
89 Colt Gt AWD HX40
93 Summit AWD Van 5 speed (2.3 stroker soon)
92 Expo AWD Van Auto
PostPosted: Tue May 25, 2010 8:54 pm
Nobody Important
Semi old thread but I'll bump it with the semi-serious offer to trade it for my 944 S2 :D
I miss CSMs
PostPosted: Tue May 25, 2010 11:57 pm
I miss CSMs
come back :o
4g61t.com
PostPosted: Wed May 26, 2010 10:35 am
I should have bought this car when it was still in Ohio :finga:
