It is currently Sat Nov 01, 2025 5:10 am
PostPosted: Mon May 03, 2010 5:49 am
Well since I got a hold of an 89 Conquest Rear subframe, rear end, and suspension (thanks to Craig "GSX'). I figured it was time to get started on my 89 Mirage Gt AWD project.
All you need to remove sound deadening.
Home made rotisserie mod
The first cut!! No turning back now!!
If I had a dollar for every V8 beaten by a colt I would be a millionaire. But I would still be driving my colt.
PostPosted: Mon May 03, 2010 7:42 am
Looking good, what are those seats out of?
PostPosted: Mon May 03, 2010 8:42 am
Love the rotisserie mod, and I can't wait to see the 89 Conquest mod. That sounds like a heavy duty rear.
PostPosted: Mon May 03, 2010 10:05 am
Your going rwd or awd? Why are you using the starion rearend instead of 1g awd? Looks like your making quick progress, keep it up!
Wow, an AWD swap using StarQuest parts? That's a new one to me. Good luck man, this should be a neat project.
PostPosted: Mon May 03, 2010 10:58 am
So the question is will it be out this year?
Goodluck :drinkers:
PostPosted: Mon May 03, 2010 1:49 pm
About time you got to work on it.. We put that bitch on the rotissery last winter ;)
:heart: you. hah
PostPosted: Mon May 03, 2010 3:34 pm
they look like newer prelude seats to me.
PostPosted: Tue May 04, 2010 1:31 am
They are Honda prelude seats. I believe 91
PostPosted: Tue May 04, 2010 1:46 am
AWD. The starion axles are about twice the thickness of the talon stuff. A local guy has been running high 9s to low 10s on an 89 rear end in his quest for over 2yrs now. So I'm pretty sure I won't be needing a replacement. After looking over Craig's (GSX) quest and seeing how easily a 8.8 independent can be fitted into the quest subframe it seemed to be a no brainer.
Also the Conquest setup is about 4" more narrow then a colt rearend so it will make room for a nice fatty under the back of the car.
PostPosted: Tue May 04, 2010 1:48 am
Goodluck :drinkers:
Hope to have it at least on the ground by the shootout. :drinkers:
PostPosted: Tue May 04, 2010 1:49 am
:heart: you. hah
Drive your ass up here and help me put it in....... slacker.. :lol: :lol: :lol:
PostPosted: Tue May 04, 2010 3:42 am
looking good mang!!!!!
Another colt being cut up in cleveland..... Also means another ground breaking moment :)
89 Colt GT, T4 T61, 2.0L, .
PostPosted: Tue May 04, 2010 10:15 am
That's a pretty cool idea. Is the Conquest gear ratio gonna work with the DSM transmission?
PostPosted: Tue May 04, 2010 12:59 pm
CSM O.G.
Tonus he said he was gonna use an 8.8 in the starion subframe. probably just use a lsd diff from a t-bird turbo coupe after that.
EDIT. I did a little research and found this:
"All 5 speed SC’s and XR7’s came standard with a 2.73:1 ratio ring and pinion
gear. Most automatic equipped SC’s and XR7’s came with 3.27:1 gears. "
The thunderbird SC is the only IRS 8.8 that I know of, possibly Lincold Continental Mark VIII's too. sadly the above info means that the gears are not worth it, and 3.55:1 LSD rearends only came in 5-speed Turbo-coupes. the auto had 3.73's
That will probably involve some customization on the axles to get them to mate to the Ford diff. There better be 20 pics or more of this part of the conversion, not to mention mounting the subframe. None of this dead-topic/long-term-update-its-running-now/pics-when-i-get-it-on-a-lift blahblah
good luck
~joe
