It is currently Fri May 03, 2024 1:09 pm
 Post subject: wiring harness
PostPosted: Mon Mar 03, 2003 10:05 pm
Just wondering if the wiring harness on a 92 laser non-turbo is the same as a 91 laser turbo? The problem I have is the motor in my 91 is performing magic tricks (disapearing antifreeze) about 1 litre for every 100 km. The car runs fine, all the plugs are normally brown, new rad, hoses, thermostat, rad cap, no visible leaks anywhere. Oil stays good.
So i was thinking of putting my non-turbo motor & computer in it. I know its in good shape. But I dont have a wiring harness for the 92, wondering about the compatability of the two motors.
PostPosted: Mon Mar 03, 2003 10:11 pm
Close but you have to run a few extra wires to make it work I myself would run a compression check on the motor I still think it sounds like a head gasket thats going if its not hitting the ground I would be concerned about where its going...
